Keeping Another Mini Out Of The Scrappy
572 replies to this topic
#376 James_eaton_thewholething
  • 1,063 posts
Posted 11 April 2016 - 11:40 AM
I'm off work in a couple of weeks so will get the body, doors, boot and bonnet prepped for that week and will then get primer done first half of the week and colour the last half. I sorted my compressor out properly. This made painting easier. I was unsure about the checkered roof but after really thinking about it and properly looking at it. It's going to finish the car off nicely and not just be a plain old black roof. Plus it will hide the bits of rubbish in the paint
#377 GT Jimmy
GT Jimmy
  • 1,676 posts
  • Local Club: S.U.N.M.C
Posted 11 April 2016 - 04:30 PM
It'll look good mate I'm sure
#378 James_eaton_thewholething
  • 1,063 posts
Posted 11 April 2016 - 04:44 PM
I hope so we shall see anyway
#379 simpsonsclassics
simpsonsclassics
  • 106 posts
Posted 13 April 2016 - 05:51 AM
Hope you manage to get this into primer its a big milestone, we are aiming for the same on out sidewalk project :)
#380 James_eaton_thewholething
  • 1,063 posts
Posted 13 April 2016 - 06:41 AM
I'm sure I will manage to very soon. Need to be at the stage of just putting stuff back on to the car by middle of next month.
What have you got left to finish on your project ?
#381 simpsonsclassics
simpsonsclassics
  • 106 posts
Posted 13 April 2016 - 01:08 PM
Yeah that is stage we are hoping to be on the sidewalk but other project and other peoples cars keep getting the way. We have just started a long term poorly pickup that didnt help
errm for the sidewalk we need to sort both doors, paint the underneath, then on top a dry build then prep and paint... loads yet.
#382 James_eaton_thewholething
  • 1,063 posts
Posted 13 April 2016 - 06:07 PM
update. i started the stripping of paint from my bottled only to be greeted by a rusty skin under the paint. cannot be bothered with replacing the skin and repairing the old frame so just ordered a new heritage one instead going to have to re skin the drivers door again as it's just poor. Wish I knew what I was doing when I did it. Feeling like I'm going a bit backwards and guess I'm going to be set back on buying something else for a bit but ah well its going to be worth it by the end hopefully
Edited by James_eaton_thewholething, 13 April 2016 - 08:49 PM.
#383 simpsonsclassics
simpsonsclassics
  • 106 posts
Posted 14 April 2016 - 05:31 AM
Wow fair enough they are quite expensive doors from heritage, but it will do the job :) It will defo be worth it in the end :)
#384 James_eaton_thewholething
  • 1,063 posts
Posted 14 April 2016 - 10:05 AM
It's only replacing the door skin the door frame it's self I have repaired but as it was the first part of the car I had ever welded or did any work on it was shocking. Going to re finish the door frame and put a new skin on. I've bought a heritage bootlid with my TMF+ discount at mini spares it's £200 including next day delivery plus it will be just scuff up the E coat, high build primer quick run down and then colour so will be nice and easy
#385 simpsonsclassics
simpsonsclassics
  • 106 posts
Posted 14 April 2016 - 01:20 PM
Fair enough to be honest wish i had done a hertiage skin on my sidewalk not happy with the pattern one. Might be getting itself changed. The idea with the boot lid makes sense and nice easy panel to have all sorted :)
#386 James_eaton_thewholething
  • 1,063 posts
Posted 14 April 2016 - 07:24 PM
So this is the state my drivers door is now in. I'm using the door skin I took off to make the new lip parts. Welding them on from both inside and out and have already got both corners on and went and picked up a new skin today. Hopefully by the end of tomorrow it will be back to having a skin on and be finished ready to prep for paint.
AFD4AC2E-097B-470B-943A-798B689AD8DE_zps
Think the doors will probably have quite a bit of filler on them but mainly on the inside which is ok
#387 James_eaton_thewholething
  • 1,063 posts
Posted 15 April 2016 - 09:03 PM
Got more updates.
D26AB1CB-132A-4F55-AE3F-AC7E15808512_zps
Door frame repaired just needs a bit more grinding and then some cleaning up with a wire wheel then some rust converter followed by so zinc and then some stone chip around the frame lip.
F5AFB213-3401-46D3-B50D-6BECFFA167F2_zps
Got a very nice box delivered today.
C0D55301-7F7C-4279-9C25-B1295889131F_zps
My brand new boot lid. Really impressed with it and will be nice to just scuff up and it be ready to paint. Decided to try my plates on it so I could see where I want it. I don't really want to drill holes in the boot but I will have to. The silver round the out side of the plates will be painted black and then have some of the rubber trim that goes between arches and the body around it so it won't scratch the paint.
I also won some twin carbs today I know I could get away with the single hif38 but I like the look of twin carbs and have always wanted to do it
All for now. Hopefully get the door finished Monday/Tuesday and then get them both ready for painting the week after.
#388 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 16 April 2016 - 06:29 AM
Like this build alot!
Can you not just use the double sided foam tape for the number plate, saves having two new rust holes to appear
#389 James_eaton_thewholething
  • 1,063 posts
Posted 16 April 2016 - 11:23 AM
I am thinking about doing it that way to be fair. It is slightly raised but All I would have to is build it up in a few layers. In fact my daily cars number plate at the front is held on that way. I will need to find away of attaching it to the front like that.
#390 James_eaton_thewholething
  • 1,063 posts
Posted 28 April 2016 - 08:40 PM
Bit of an update
So I picked up my twin carbs
148392C4-5ED8-4B43-9668-6B036EAFB775_zps
Then set about modifying them slightly.
2EE51C07-9049-4177-914A-5D5C7977635A_zps
739E965E-703C-479B-B509-D30B7CEA12DC_zps
They just need new jets and spindles then all is good for them to go onto the car when finished.
Also got the exhaust hole cut out and shaped so the exhaust can be tucked up a little. A mixture of cutting, filing and hammering and you are left with this.
F294D82F-C7B2-4537-9C64-3D62B1EA0B8F_zps
61AA1F19-8B4D-47A2-AA56-3882E838122D_zps
Next onto the next big step although I'm quite behind where I want to be but it will be done soon.
D06C449C-9073-426C-940E-A8CE16F6D0D8_zps
All body filler is done and rubbed down and all seam sealer is finished. After all of the I set about recovering the garage in dust sheets and I even did the floor for good measure. Hope people don't think I'm doing anything bad when I come out in my paint suit lol.
Next the car is now ready to be primed. Going to rub the car down first the re do some of the zinc primer and then get onto the hi build.
53C128DE-6463-49EC-A4BA-437C26021E19_zps
It's all masked up and ready to go.
All for now
