Keeping Another Mini Out Of The Scrappy
572 replies to this topic
#331 James_eaton_thewholething
  • 1,063 posts
Posted 14 March 2016 - 10:38 AM
So quick update.
Nothing done in the mini as been sorting out my 205. After cold nights out side with a crappy lamp and lots of swearing it's all back together and driving which means getting back on the mini. Now as it is payday tomorrow I will be going and pricing up and buying paint this week. Going to get doors, bootlid stripped to bare metal any filler work done then zinc primed. Will also get the bonnet prepped.
All for now
#332 GT Jimmy
GT Jimmy
  • 1,676 posts
  • Local Club: S.U.N.M.C
Posted 14 March 2016 - 10:11 PM
Good luck with the painting matey. Glad you got your GTI back on the road. I've given up on my ford so have just ordered my new car :D
#333 James_eaton_thewholething
  • 1,063 posts
Posted 18 March 2016 - 04:05 PM
Quick update
6D9A2D64-D7D9-45F7-8C66-86F2E242DE99_zps
All the paint. Just got to finish the filler bits on passenger side then will get on with cleaning out the garage and getting all of it covered in dust sheets and then on with the high build. Getting proper excited now
#334 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 18 March 2016 - 06:08 PM
Nice one. Get that done then you can start on mine :D Had a few hours on mine today
#335 James_eaton_thewholething
  • 1,063 posts
Posted 18 March 2016 - 09:26 PM
Haha guess I will something to do to pass the time
#336 Daz1968
Daz1968
  • 2,058 posts
Posted 18 March 2016 - 09:39 PM
Best of luck, it's rewarding once the paint goes on, just take your time
#337 James_eaton_thewholething
  • 1,063 posts
Posted 18 March 2016 - 10:09 PM
I did a quick test using the satin black on an old door skin to test my rebuilt compressor and to understand how the gun runs and what adjusts what. Got it running at around 2 bar. Just have to work out a way of fitting the air filter back onto the compressor which snapped off. Also have two inline filters to trap as much water as possible. Really looking forward to it and I enjoy painting
#338 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 18 March 2016 - 10:13 PM
Just drive it ha ha
#339 James_eaton_thewholething
  • 1,063 posts
Posted 19 March 2016 - 06:55 PM
Got a few things done and a new item arrived today.
AE3E224B-A402-46F3-A3D1-84B1FD8D5E37_zps
Need to re paint these as the coating is terrible and scratched in places. So drilled the the rivets out and put some m5 stainless bolts through
8F19634C-FBF2-46AD-A4AD-A9D408DAE11D_zps
New petrol cap turned up today. This will mean I will be able to put the tank in the middle of the boot but still be able to fill it up from the regular side. Plus it fits the look of the car. Going to paint it satin black along with any other bits of chrome trim
All for now
Edited by James_eaton_thewholething, 19 March 2016 - 06:58 PM.
#340 James_eaton_thewholething
  • 1,063 posts
Posted 21 March 2016 - 03:05 PM
Boring stuff done today really but at least I can get back onto the mini and move forwards.
0F0982EB-61BE-4564-BE8D-CCAC67795E0A_zps
Got the fuel cap fitted. Started by filing the hole out from 73mm to just over 76mm. Then hammered the hole so it sat flat on the body. It has a cork gasket on it so it filled in the little bit of a gap and its tight against the body. Took my time with it so it doesn't need any filler around it to smooth it out.
29FD24ED-9068-462B-96A7-76E5F585EDD7_zps
Shot of it from the inside of the car. Once the fuel tank is in I will work out a way of supporting the pipe so it doesn't just flap around in the boot.
After this I started to tidy up the garage of any dust, bits of metal, rubish and anything that will get in my way when painting. Next step is to empty the boot out of tools Hoover the dust out, seam seal everything then spray the boot floor in stone chip then do my first bit of spraying and get the boot in satin black.
#341 mina08
mina08
  • 255 posts
Posted 21 March 2016 - 03:13 PM
Great job, what size tank are you putting in, in the center you said?
#342 James_eaton_thewholething
  • 1,063 posts
Posted 21 March 2016 - 04:29 PM
Going with a 6.5 gallon tank. I know it's a gallon less than the standard one but by the time it's filled up and got fuel in the pipe leading to the tank it probably won't be far off. I will be running a 1030 so won't drink tonnes of fuel anyway
#343 James_eaton_thewholething
  • 1,063 posts
Posted 25 March 2016 - 03:18 PM
Go the boot floor and arches in stone chip and all the boot floor, heel board, rear valance and rear arches seam sealed. That's another tube of tiger seal down and one to go.
D60BDDA9-C433-4F27-859D-5CA3B8980D39_zps
Going to get this in satin black over the weekend.
47878F76-B8F6-4DFD-A9AC-D712D440AAEA_zps
My stage one compressor lol. Retro fitted a K&N to my compressor as the original one broke.
All for now
#344 James_eaton_thewholething
  • 1,063 posts
Posted 31 March 2016 - 08:33 PM
Been getting on with some fun stuff recently. I will let the pictures do most of the talking but will explain problems I've had.
B7B619ED-E6B5-47AE-AED4-24BF4EC347F4_zps
Go the garage all covered in dust sheets and got all breakthrough surface rust removed and then covered in zinc primer again.
D2E5A74D-1192-43CD-8910-26730E4D7498_zps
29B39E56-36FD-4455-A323-B9B2F29E5A1B_zps
Got inside the boot and inside the engine bay in satin black. Need to do another coat in the boot but at least it looks better.
23670026-F637-4B91-8AFE-8DDF7741B25F_zps
Got the roof in high build. I had a couple of issues with some of the paint splitting on some of the seam sealer because I was a little impatient and didn't let it set properly. So after it dried I had to take the the gutter and round the roof back to bare metal and start again. So another 4 coats of high build so it's level with what I had left and it's now ready to sand down tomorrow after work and as long as I don't run out of time might even get chance to get a couple of coats of black on.
#345 Daz1968
Daz1968
  • 2,058 posts
Posted 31 March 2016 - 08:38 PM
Looking good, painting is the part all the hard work beforehand starts looking better, welding and panel replacement although major jobs just don't give the same feeling as seeing the car in paint.
