Keeping Another Mini Out Of The Scrappy
572 replies to this topic
#241 James_eaton_thewholething
  • 1,063 posts
Posted 19 January 2016 - 12:03 AM
A little purchase and some other bits of paint over the past few days.
23C66CF7-6176-4ECA-BF9A-4F34D7A8B1CD_zps
77C5189E-44D6-471F-8ED0-734811090347_zps
Painted gear knob red and the gauge needles red. Also painted the white plastic black and is now not visible through the lenses.
E184EE11-3E24-4DA9-AE20-799228914317_zps
Picked up these second hand off eBay. They are in good enough Nick a couple of tears in a few places but I've sewn them back up and you can't tell.
9DC7DA52-FFC2-4BD0-8ABF-068C90630ED5_zps
One is a carbon/Kevlar one and that will be the drivers one didn't realise how light they are.
A4837955-949D-4599-90B8-0621DB7E1DEF_zps
The other is a fibreglass one a little heavier but not much and that will be the passenger side one. The Kevlar one is more comfortable but both are quite comfy. Unfutunaly the FIA homlogation has expired but that doesn't matter it's not a race or rally car so it will be fine.
Tomorrow I'm going to make my seat mounting brackets and weld them into the car that will mean I can then get on with prepping the floor ready for stone chip.
All for now
#242 James_eaton_thewholething
  • 1,063 posts
Posted 21 January 2016 - 10:07 PM
Been busy the past few days fabricating stiff and being able to fit the seats in the car. Also I can now finally fit seat belts if I needed to as all the captive plates are in.
0B5EB8A1-753D-490A-B47C-7A5AD9D8BBAD_zps
Anyhow I took the sheet of 3mm steel and proceeded to draw out my jigsaw. It took ages to cut all the pieces out with a 1mm thick cutting disc but ah well got nice straight lines
35168276-B72C-40D9-A246-182B9E6841D6_zps
Drivers ones made up. It took ages to get them right with having to keep moving the seat in and out of the car it's a good job it's light.
77D7930B-E11A-4722-BC54-5C88EFBEBAF0_zps
Welded into the car. I then started to make up the passenger one which was even more annoying but ah well it's done now.
C2D05D0A-973F-4386-9742-A44A5847B2FF_zps
Passenger side welded in. They are made from 3mm steel sheet and 3mm X 25mm box section so not going to bend anytime soon and niether will the floor sag from the seats.
2F46F99B-1894-4BDE-936C-F06D799C4470_zps
03C7895F-569E-4609-9213-5873EF5C2EF3_zps
Passenger seat is sat behind the drivers seat as the wings are quite wide but it doesn't matter and at least the passenger won't block my view
All for now
#243 WPD
WPD
  • 85 posts
Posted 22 January 2016 - 03:50 PM
Didn't think the dashboard would turn out well but that black wrinkle paint makes all the difference! Looks great
#244 James_eaton_thewholething
  • 1,063 posts
Posted 22 January 2016 - 05:22 PM
It definitely did make all the diference even I didn't think it would turn out right but now I'm happy with it
#245 James_eaton_thewholething
  • 1,063 posts
Posted 22 January 2016 - 05:27 PM
Got a little done this morning. Cleaned up the welds and covered them in zinc primer.
Then set about painting the floor with stonechip.
8BF68363-7780-450E-BF34-C3768CC4AB76_zps
17F89ED9-D16C-42B0-8313-ECB791C0894A_zps
Makes a huge diference to the car. Some of the paint will need to be removed to weld in cage spreader plates but that will be when I get paid next month
All for now
#246 GT Jimmy
GT Jimmy
  • 1,676 posts
  • Local Club: S.U.N.M.C
Posted 22 January 2016 - 06:35 PM
Looking good mate, when do you think it'll be on the road?
#247 James_eaton_thewholething
  • 1,063 posts
Posted 22 January 2016 - 07:08 PM
All being good hopefully latest August. Hoping to be done by June. It's all money dependant. Everything now is expensive
#248 James_eaton_thewholething
  • 1,063 posts
Posted 24 January 2016 - 01:59 PM
Managed to start welding the steering rack mount on yesterday then ran out of wire. Bought some more today and will finish it off and also weld on the engine steady bracket.
Since I ran out of wire I thought it was time to paint my mirrors since I wanted to do it ages ago and it's one less thing to paint when I come to put everything back together.
46097F60-9D76-4F2B-BBE7-014574C3EAF4_zps
Think that look really nice and is going to be a different touch than being a solid colour. The grill is also going to have a single red stripe running through it to match
All for now
#249 James_eaton_thewholething
  • 1,063 posts
Posted 26 January 2016 - 04:45 PM
Back to work this week so back to getting little bits done at a time.
4DE6F813-EB92-45DE-8002-5131C2E16079_zps
15E81CCB-DFD7-43BC-9D9D-E466B196C0DC_zps
Got my group 2 arches on the car today so that's one less job to do. Better to do it now than after paint.
9A2A18BA-6602-4178-9A95-B7EC42F2300A_zps
Used some m5 stainless bolts that go into a rubber rivnut easier than having to worry about a self tapper rusting or even regular rivnuts rusting.
All for now
#250 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 26 January 2016 - 06:45 PM
Group 2s are the best looking arches for me, not too wide
#251 James_eaton_thewholething
  • 1,063 posts
Posted 26 January 2016 - 07:01 PM
They are the wider version because my wheels stick out loads past the metal arch 😎
#252 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 26 January 2016 - 07:25 PM
Didn't think they were that wide, I like the look of them in the mags. What wheels are you using?
#253 James_eaton_thewholething
  • 1,063 posts
Posted 26 January 2016 - 07:40 PM
There's two types group 2 rally and group 2 race these are the race ones about an inch wider. I will be using 10x6 wellers. Had to cut the front of the wing and the front panel bigger so that the wheel will clear it haha
#254 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 26 January 2016 - 08:35 PM
When I bought the GT my original plan was wellers, but now using what I've already got
#255 James_eaton_thewholething
  • 1,063 posts
Posted 26 January 2016 - 08:38 PM
They were my dads and are older than me but need to get them re powder coated for a second time but I'm also going to have them coated satin black
