Keeping Another Mini Out Of The Scrappy
572 replies to this topic
#151 James_eaton_thewholething
  • 1,063 posts
Posted 30 October 2015 - 09:58 AM
Those grille buttons are a smart idea.  Can you remove the grille OK even with the spot brackets in place?
Yeah you can pop the buttons and slide it in either direction. I'm going to put a thin strip of rubber on the back of the grill and the backs of the brackets as to not remove paint from with the car or the grill
#152 James_eaton_thewholething
  • 1,063 posts
Posted 30 October 2015 - 07:36 PM
As I have the best fiancé ever she told me that I could go work on the car so I got a pain in the bum job done.
F02DDDE0-8242-45C5-A76D-CE228C0F5FD1_zps
90AF631C-EE47-4C0C-AD08-A48CD990693F_zps
Got the paint taken back a and the all the bits of rust left out of the pitted part. Then covered over the welds with a skim of filler. Also covered over the bumper lip with filler as to his the welds.
5498F1DB-982B-44ED-AE7B-9DBE7EA3807F_zps
ED56636D-CC18-4A6C-8200-9911A7E9F65C_zps
845F3C6C-0085-4158-8C73-0E4696100C05_zps
292CDC72-E15A-4164-BEDB-B18C0D1B9AF1_zps
755DE4B6-D919-4329-9513-92B4424651C8_zps
So covered it all on primer again and it now looks like it was never repaired so I'm happy. Also started on putting filler on the fog light holder so it blends into the valance.
D766B754-8C35-4C67-AD13-DD6FA2B44BEE_zps
Got back in the house and the misses said we are now like the princess and the pauper or she is a first class passenger from the titanic and I would be a third class she is so mean at times but I can't complain she lets me work on the car
All for now
#153 James_eaton_thewholething
  • 1,063 posts
Posted 02 November 2015 - 10:49 PM
Not much progress in the past couple of days as I spent the good part of 7 hours cleaning dust and bits of old car out of the garage and tidying it up again in order for it to be easy to paint and get around the car without an obsticle course.
4FBDDA82-A3E6-4C2E-B277-81ACC6CC3491_zps
Made good use of the old time table holder I got from work when the old bus station was coming down.
99DF71DC-9409-4D39-8BD5-CA070734F3A8_zps
I took the padding off of the top dash cover as it was horrible and torn anyway. My aim is to clear off the surface rust cover in zinc and then cover it in fake alcantara cause I got to save money somewhere.
09E82E3A-BA95-46A3-9175-387B966B78F6_zps
Cut both ends of the Lowe dash rail off ready to make up new parts. Ground the welds back from filling over holes and the from blanking off the air vent. Covered in kurust.
2A7CE6FB-6769-441C-A78F-8A4C699FDCFC_zps
Got home from work and covered in zinc primer.
D1695DF1-825B-4E62-8F19-C9E943351226_zps
Welded this bar in to add strength to the lower dash rail. It's inline with the bolts for the steering column, but is hidden behind the clocks. All will be revealed why soon enough.
Going to finish (hopefully) the bulkhead and lower dash rail tomorrow then only have, B post to floor, boot floor to finish, then need to clean up the rest of the underneath of the boot floor add a couple of seam welds to the valance closing panels. And add the outer sills then get on with paint prep
#154 James_eaton_thewholething
  • 1,063 posts
Posted 03 November 2015 - 11:50 PM
I managed to get the lower dash rail finished this morning and all the welds ground down on the bulk head.
B9CF7390-1613-4B29-87BC-835B93D66350_zps
49318941-5F3B-4013-ADBF-32B5C134B04C_zps
B5B8C1EC-D2C8-49BB-9FE6-C4DF494DA712_zps
The lower rail is really strong now so should have no flex when the steering column is attached.
A350C82C-2783-496A-973F-1A3DD33868A7_zps
I also got the hand brake mounts welded on I seam welded it all on so its not going anywhere anytime soon.
23FC65CE-BB4B-4465-A944-BD6669B6D06C_zps
Folded over the A panel completely and then put some sealer in all of the panel gaps so hopefully it won't get water trapped between and rust
All for now
#155 James_eaton_thewholething
  • 1,063 posts
Posted 07 November 2015 - 10:40 PM
So after a good few days of getting up early to work on the car before work then go to work and then come home from work and jump straight back into the garage a small bit of progress has been made.
4436727B-ACE2-48F7-95BD-36CA7D9A9CCC_zps
A picture of how the rear of the car was to how it is now. Quite a transformation.
Next thing was to set about doing the boring stuff and the time consuming things. This was mainly sealing up all the joints.
4BF2ECC8-280D-4CCE-84D1-FEFD4C98E3FC_zps
E5F4EF63-5B7B-4212-A393-31BE43BCBA1B_zps
8471FD89-47FD-4CBF-B295-0CC5F18F2009_zps
After doing the inside of car I set about sealing up under the wings and some parts of the front page which will definitely see water.
4CE9E2D6-BBAC-4E74-965C-65140F88365C_zps
EADA9DFF-C511-462B-AA1E-5E47DED15C40_zps
1908CC3A-4CF1-4A42-AAC2-AC790D4A2454_zps
168FDE2F-85B3-45CD-BFE9-94E824A6C760_zps
4BA397E8-172A-4033-974B-8422F025F607_zps
Got a few discolouration spots on the seam sealer in some places not sure why as when you rub it back the discolouration goes I'm going to take it all off re cover in primer and re seal.
B81B438C-15A9-436D-96CE-34ABA299F6FC_zps
0B0B3432-CC82-4D80-9E1A-0599C26749EC_zps
Made up some plates to tie the B posts to the floor and to add a little strength to where the seat belt mount points are.
That's all for now I'm off work for a week but I'm surprising the misses by taking her away to Paris and she doesn't even know
Edited by James_eaton_thewholething, 07 November 2015 - 10:42 PM.
#156 James_eaton_thewholething
  • 1,063 posts
Posted 14 November 2015 - 09:48 AM
So I got back from Paris and luckily a couple of days before the recent events. Quite glad because it wasn't that far from our hotel.
Anyway got back onto the car yesterday and decided to strip the front and fill in the imperfections and little dings. I also welded in a piece I had cut out ages ago to block off the passenger side air hole in the front panel.
741927EC-F94B-491E-AE2B-58EB8DD0899E_zps
D1E28D08-0AD6-4778-8894-48E50A6B52D5_zps
Took it back to bare metal and really wanted to keep it like that because I think it looks cool. I then welded up all of the screw holes for the grill. While doing that the earthing clamp on my welder broke but it's a good job I had a new one ready.
CBEFE9A4-4250-49A9-A2AA-72E215A08C1D_zps
E3EE4F0B-D2F9-409E-8C4F-A562F210647E_zps
D95823BD-F181-4997-AC89-1643990F7F9C_zps
024AC289-768E-4BB8-8D52-99DA78B9F99C_zps
34457591-D441-4D61-A768-843B72A8BF2C_zps
Put filler over all of the problem areas then rubbed it down. Then started to cover in zinc primer.
FEA01BD0-9DFD-4ED4-AEAB-CA5014D14DF2_zps
01770A8F-671C-4871-8195-F9CA821DC4D8_zps
I feel that I did quite a good job with the welding in of the little piece and then the blending it in so both sides look the same
22E2E41A-3051-4BC8-93DA-6C923C5ACA4E_zps
So the front end is all one colour now. I just have the A panels to clean up mad blend into the car and also to put filler of the join on the scuttle. I will then finish the passenger side.
I'm going to push paint back to the new year as I have other things to buy, fit and fabricate and wouldn't want to paint just to remove it
All for now
#157 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 November 2015 - 03:49 PM
Nice one James
#158 James_eaton_thewholething
  • 1,063 posts
Posted 15 November 2015 - 10:41 AM
Nice one James
Cheers Ben it's getting there I guess
#159 62S
62S
  • 1,253 posts
  • Local Club: You must be joking!
Posted 15 November 2015 - 12:21 PM
Just a small observation that might save you a bit of hassle later - your nearside inner sill seatbelt mounting doesn't seem to have a captive nut?
#160 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 15 November 2015 - 02:18 PM
good work , your going to have a nice mini . Also love the pug 205 gti on page 2
#161 James_eaton_thewholething
  • 1,063 posts
Posted 15 November 2015 - 04:08 PM
Thank you for noticing, I haven't gotten around to welding it in yet. I have left the outer sills off for the time being as I want to seam seal the door step to floor joint from underneath
Edited by James_eaton_thewholething, 15 November 2015 - 04:09 PM.
#162 James_eaton_thewholething
  • 1,063 posts
Posted 15 November 2015 - 04:13 PM
It will be a nice car when done cannot wait but still got a lot to do before its done. The 205 is a good car still that has a few minor issues and some welding before its mot next year. Think there will be a big difference in power when I have both cars on the road and go between them
#163 BMH
BMH
  • 108 posts
Posted 19 November 2015 - 10:59 AM
Have you tried the coil overs in the rear yet as the last one I did I had to re radius the shocker tower wider as the coil over rubbed.
Bryan
#164 James_eaton_thewholething
  • 1,063 posts
Posted 19 November 2015 - 08:10 PM
Bryan
I haven't bought them yet. I am going to be going with the protect ones, as a friend of mine uses them and I followed what he told me to do and what he did to his. I already have bent the inner strengthening section right back. When I get them though I will be sure to check. Cheers for the heads up 😊
#165 James_eaton_thewholething
  • 1,063 posts
Posted 19 November 2015 - 08:32 PM
Not been Able to get too much done recently being back in work and also had to sort a few issues on the 205.
Over the past two days I've been getting on with fitting the drivers side outer sill.
2FEF14DA-5E71-4A57-B61F-E43445796DB7_zps
Tested the fit and it was going to be easy to fit.
EFFA1930-3476-44C7-AA40-1AE206F9DBAC_zps
150496DC-6EFA-4294-9143-98825BE41991_zps
All welded on I forgot to take pics of the prep but I will when I do the other side.
F187983E-0635-4913-9377-067DD9F959C9_zps
Welded up the jacking point hole and a couple of the other holes in the panel. I welded it on from inside the car as to look cleaner only place I couldn't was inline with the crossmember.
9BBFBDAC-653C-496E-A624-3CECFEE6E24C_zps
Google maps still has my car one the front path.
0469BD6C-5E1B-4414-8955-BA39D60ACE98_zps
I refitted the two step part of my rev limiter on the 205 so I can be a big child and shoot flames as it only cuts spark
all for now
Edited by James_eaton_thewholething, 19 November 2015 - 08:33 PM.
