Mk3 Mini 998 Timing Chain Rattle
20 replies to this topic
#16 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 17 March 2015 - 10:14 AM
Turns out this engines got no tensioner at all and the cam sprocket doesnt take the rubber rings.
#17 tb205gti
tb205gti
  • 186 posts
Posted 17 March 2015 - 10:23 AM
Get rid of the rattle for good - convert it to cambelt :)
#18 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 17 March 2015 - 01:10 PM
Funds dont allow in this case im afraid. Sure once replaced it will last a while!
#19 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 17 March 2015 - 02:58 PM
Always, always change the sprockets when you change the chain.  As said, the chain will wear the teeth to suit itself, while that combo may last a while, as soon as you put a new chain on those old sprockets the wear rate will go up massively.
#20 ACDodd
ACDodd
  • Mini Docs
  • 2,741 posts
Posted 17 March 2015 - 03:53 PM
Do what the factory did. Fit a tensioner as the A+.
AC
#21 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 17 March 2015 - 05:22 PM
The sprockets are being replaced, i have been advised to go duplex anyhow but if I stayed simplex i would replace the lot.
