Mini Transporter Trailers
105 replies to this topic
#91 darkcat
darkcat
  • 398 posts
Posted 25 August 2015 - 07:48 PM
Hi all, thanks for the positive comments :-D
To answer some questions:
> Brake cables: these are routed from the drum plates to the centre of the middle cross-member, not attached yet in the photos.
> Final cost: As stated previously i was looking for it to be under £2k all in (thats the full braked trailer, finished, galvanised, VOSA tested and approved, winch, lighting, ramps, 4-point wheel tie-downs, basically a ready-to-go package) - it is looking to be well under this, but will confirm once ive calculated all costs.
> I'm working to get the thing fully finished in the next couple of weeks and hopefully out to some shows!
I need to do a good amount of loaded road testing with it to be absolutely sure the design is strong enough, so would not anticipate any customer trailers this season - i have to be 200% sure the design is durable.
On the positive side ive shown this to a few other forums that i frequent (non-mini) and they all love the concept, a big advantage of the modular design is it can be widened / lengthened for other cars to fit.
#92 Carlos W
Carlos W
  • 10,114 posts
Posted 25 August 2015 - 07:52 PM
Will it still be foldable with the cables in place?
I'd be tempted to leave the hitch on and mount a tow ball to the wall
#93 clubman91
clubman91
  • Just Joined
  • 137 posts
Posted 25 August 2015 - 07:56 PM
Could be very intreseted,
What do you think the rough final weight will be.
Cheers,
Mark.
#94 darkcat
darkcat
  • 398 posts
Posted 25 August 2015 - 08:00 PM
Carlos - yes, they are attached to the front half of the trailer as are the suspension and a-frame assemblies.
The A-frame detaches from the bed with just 4 bolts, and then you can remove the hitch, leaving you with 2 box section lengths and the hitch to arrange with the bed wherever you can.
Its still a bit "work in progress", being the first prototype, but it really is looking positive :-)
#95 darkcat
darkcat
  • 398 posts
Posted 25 August 2015 - 08:02 PM
Hard to say on weight at the moment Mark, its certainly not ultra light, but as i said its over-engineered.
As a guide, with it folded i can easily lift it up to the wall as per the last photo myself, and im no body builder!!
I will weigh it when i can.
#96 Carlos W
Carlos W
  • 10,114 posts
Posted 25 August 2015 - 08:04 PM
Very much so
#97 darkcat
darkcat
  • 398 posts
Posted 25 August 2015 - 08:10 PM
Also, I cant sing high enough praise for the ESAB welding kit.
I've had cheap SIP/Clarke welders in the past which struggled to even do a bad weld!!
This thing has incredibly stable beads. (ok experience helps but...)
#98 darkcat
darkcat
  • 398 posts
Posted 06 September 2015 - 08:59 AM
Hi all, I'm at MINI FEST in Utoxetter today in the autojumble if anyone fancies a chat about trailers :-)
#99 Miniman1987
Miniman1987
  • 79 posts
  • Local Club: IMOG
Posted 06 September 2015 - 09:22 AM
Wow! What a fantastic idea!
#100 darkcat
darkcat
  • 398 posts
Posted 29 January 2016 - 08:56 AM
Update:
Will be going for galvanising soon, so look out for it/me at this years shows :-D
#101 minisprint
minisprint
  • 1,036 posts
  • Local Club: GR8 minis
Posted 30 January 2016 - 10:36 PM
Seen this trailer when collecting a fibreglass shell looks good !
#102 minisprint
minisprint
  • 1,036 posts
Posted 30 January 2016 - 10:39 PM
If you need a test or two doing got all sorts of trips and collections to do ;-)
#103 WPD
WPD
  • 85 posts
Posted 30 January 2016 - 11:14 PM
Could it be towed folded in half?
You could yes, although you would need a 2nd set of lights and number plate on there to be legal - its certainly on my plans, but an option.
quick release number plate and lights?  ;D
#104 leyland73
leyland73
  • 158 posts
Posted 27 August 2018 - 07:00 PM
Any updates on these trailers?
#105 darkcat
darkcat
  • 398 posts
Posted 09 January 2019 - 12:14 AM
Yes! So update: I made one, and it works :-)
I have 3x sets of the cut parts so can make more or sell the parts + plans.
