My 1981 clubman blew a thrust bearing a few months ago and after finally getting everything back together I couldn't get the clutch to disengage. I have replaced the arm, pushrod, slave cylinder and both clevis pins since replacing the clutch plate and bearing. With the starter removed and the clutch pedal depressed there is no visible movement of the clutch assembly. Please help this is my dream car and its killing me seeing it like this.
No replies to this topic
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
