The Green Beast Rebuild!
454 replies to this topic
#106 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 02 June 2015 - 09:25 PM
Welded the crossmember on today. Got measurements from my old floor. Took a lot of persuasion to get it to fit properly! Me standing on it And a jack under the bracing at one point!
4B043B4B-5863-49BB-9689-8AA2CE7AD302_zps
BB1794CC-8547-43F9-9ECD-E17043FE8A15_zps
Then I found allot more Rot.......
A37136E3-DA92-465C-83BC-5C56121DD94B_zps
#107 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 04 June 2015 - 07:21 PM
So tonight I measured and cut out a closing panel for the inner sill. Took my time to get it perfect and will be copying this for the other side.
B83C8F5C-05AD-40D2-9C4C-B7B1A83E919C_zps
Here it is cleaned up also sorted the peice missing from the b post.
8C780A18-FB4D-4D47-88B7-3FDC97CA77EF_zps
Also ground down some of the bits in the front footwell
96C57FE3-E087-4205-B848-B42B5ECE6D5E_zps
Up next is the crossmember welds to grind down!
#108 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 06 June 2015 - 02:28 PM
Ground most of the welds down on the inside today just some seam welding along the back needed when I get some more gas. Also removed rest of bracing.
C695F571-6A41-49AF-A55B-BF82E37CF280_zps
5A197BF5-53F8-44CA-BFFD-7F209458B088_zps
I have given the areas done a coat of zinc primer just so I know what's done and what isn't !
Sorted the other inner sill closer too.
BBAF781C-8D2A-498B-9941-5FFAC4F2DEDA_zps
Hope I'm not boring you all to death XD it's gone like a graveyard !
#109 johnsn
johnsn
  • Just Joined
  • 69 posts
  • Local Club: OMS
Posted 06 June 2015 - 03:52 PM
No, I'm not board at all.
I just don't comment much.
Inspiring work!
johnsn
#110 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 06 June 2015 - 05:24 PM
Inspiring work!
johnsn
Cheers buddy !
#111 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 June 2015 - 05:33 PM
Looking good!
What are you doing with the back of the car now you have removed the seat base overhang and companion bins?
#112 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 06 June 2015 - 05:38 PM
Looking good!
Thanks mate :) yeah seat and bins are gone now as I'm having full cage and solid mounted buckets! No need for rear seats :)
#113 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 08 June 2015 - 08:41 PM
Right tryed to fold some rear quarter window repair panels and failed big time so I'm going to do it in 3 pieces now :(
This was the jig
4F597398-ED3E-4567-8224-58AA9E7BF228_zps
So I scrapped that and got the waist rail lined up and ready to fit but my gas ran out!!!!
5F5CF031-3646-46C9-A54A-E0EA1FAA5FAD_zps
#114 Baldspeed Racing
Baldspeed Racing
  • 1,193 posts
Posted 10 June 2015 - 11:57 AM
Good works, defo coming along well now
#115 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 10 June 2015 - 04:03 PM
Thanks a lot buddy !
#116 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 11 June 2015 - 09:56 PM
Made some progress with the quarter window tonight. It's very tricky to make the corners perfect but it's getting there.
B616E08A-608C-4F87-80E7-BAA119545CDE_zps
Going to finish it tomorrow then start on the d/s hopefully that's not as bad ! XD
#117 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 20 June 2015 - 01:24 PM
Tryed on the new refurbed drivers door today. Gaps need fettling a bit but should be ok considering this side had a new A post !
468A53FF-9452-42D4-B95E-70B470109A1C_zps
So I will get this side all sorted and fit the A panel this week hopefully
#118 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 22 June 2015 - 08:29 PM
So tonight I finished the p/s quarter window as it was bugging me being half done !
8DDE7AF4-D076-4239-BAFD-93429CBA1388_zps
So this made me think is the other side as bad or even worse ? Gave it a wire wheel off and was very pleased ! It's not been welded up before and much less work to do :)
623B5733-C6EC-4DDE-ADC0-C186035EC95E_zps
So before I went inside I got the stupid fake filler neck hole welded up.
92A8320E-A1FB-45E2-81B3-4E27058EEFBD_zps
#119 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 25 June 2015 - 09:34 PM
Done some more work on the door/ a panel today. Ready to weld the a panel on once I get hold of some panel bond to put between the two skins.
63B4A2DD-0D38-4FD6-AFD8-C53AF6F3FC80_zps
I'm not trying to get perfect concours gaps on this car but decent size gaps non the less!!!! :)
ED222179-D8B4-4C94-BB90-49CC0E6B066B_zps
CBD9AC41-843D-48C1-BFFA-5D627E2B35D1_zps
#120 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 05 July 2015 - 04:19 PM
Welded the a panel on today used panel bond between the two skins to make it extra strong :)
F0C8D27A-560E-414F-B5B9-A7267649F2B3_zps
Put the door on and the gaps are good but door still sits slightly proud of the a panel so I need to file the Hinge holes out more.
550EDDCC-4743-4A0B-8F69-4F2FC573CA3F_zps
F3748A38-3AB0-48D3-BF6A-BC6CB4F1974A_zps
    Bing (1)
