The Green Beast Rebuild!
#271
Posted 21 May 2016 - 05:26 PM
Will a sip mig welder be up for the job on a mini shell? Is it the gas that needs to be consistent as the welder I have has a tiny white bottle, what thickness wire have you used? Also do I spray new old panels with a primer before welding? And ace retain primer after?
What bars do you use to turn the shell over?
Thanks and keep up the good work!
#272
Posted 21 May 2016 - 07:59 PM
Great build! I am going to start a project fairly soon, I have a few questions and was hoping you could point me in the right direction!
Cheers mate!
Your welder should be ok for welding up a mini but a decent size boc/hobby weld bottle of gas will make it a whole lot easier! I use 0.6 wire! All of the black coating on new panels should be removed and replaced with a decent quality weld through primer. You can also give box section panels a coat of brush on paint like zinc 182 on the inside away from areas you are welding to give added protection. After all welding and she'll is painted box sections can be filled inside with wax oil to provent future rot! I turn my shell onto its side by myself as it's quite light! But used paddy hopkirk roof bars when it was completely upside down ! You will need around 4 people to turn it safely
#273
Posted 21 May 2016 - 08:00 PM
Cheers mate!
#274
Posted 25 May 2016 - 04:12 PM
What thickness material do you use? 1mm, I have no idea what people do with underside of wings etc as when I get one I intend to do a underside overhaul to make it completely solid, I'm not sure if this will lead to a complete restoration but I have no experience regarding engines / wiring etc! Or anything yet lol
I Hope you don't mind all the questions
#276
Posted 05 September 2016 - 01:02 PM
Very nice work so far
#277
Posted 05 September 2016 - 09:34 PM
Thanks a lot mate :)
#278
Posted 06 September 2016 - 05:52 AM
Looks great dude nice work!
#279
Posted 09 September 2016 - 07:14 PM
Now this side is basically ready !
Will chuck some etch on it tomorrow evening and crack on with the front end on Sunday!!!
#282
Posted 22 September 2016 - 08:36 AM
#283
Posted 24 September 2016 - 04:32 PM
Then a couple of the front
Today I also went and got 3l of the expensive high build primer and bought the primer gun home from work !!!!
Should be cracking on tomorrow with it hopefully get it all primed up including the roof fingers crossed!
#284
Posted 24 September 2016 - 08:42 PM
Everyone in the trade seems to be sing the Octoral lately. Us included.
It's a really good product.
looking good by the way
Ben
#285
Posted 24 September 2016 - 09:03 PM
Ben
It's a decent primer and rubs down nice too ! I will never use the mipa high build again because it peels off plus it's harder to rub down.
Cheers for the feedback mate I'm trying my best!!! :)
