I went down a slightly different route of welding the nut to the stud. I had trouble getting the nut to stay welded to the broken bolt and stay in shape to fit a spanner or socket. I reckoned the nut needed to be shallower to maximise the heat in the weld and could be torqued up with a pair of grips. I bought some steel M8 wing nuts.........
Mig at maximum setting. I placed a button of weld on top of the broken bolt then put the wing nut on top of it and welded it together. I then ran a large bead of weld across the top linking the two wings together - white hot. After several attempts where the wing nuts broke off the broken bolts, they held up and out came the bolts - simples.
One b*stard broken bolt.
Wing nut welded to bolt
Waiting for the grips. Will the weld hold or Not?
Bolts removed from subframes plus nuts where the weld failed.
Adam
Edited by BusheyTrader, 28 February 2015 - 10:42 PM.
