What Engine Do I Have?
Best Answer Spider , 22 February 2015 - 10:01 PM
Working from the Freeze Plug type, size and number of them the block is a Pre-A+ 1275, no question.
Working from the Thermostat Housing orientation, the Head is also 1275.
Go to the full post
25 replies to this topic
#1 87advantage
87advantage
  • 53 posts
Posted 21 February 2015 - 11:31 AM
How can I tell what engine I have in my mini the previous owner has put a different one in and has removed the Engine number plate !
#2 Ethel
  • 25,865 posts
Posted 21 February 2015 - 11:50 AM
There are some obvious differences:
1275's don't have tappet chest covers and the thermostat housing locates at a different angle on the head. Though you could put a 1275 head on a smaller engine.
Different compression ratios were achieved with different piston crowns -  flat or dished...
A and A+ blocks have different fitting for the alternator and distributor....
#3 sledgehammer
sledgehammer
  • 3,096 posts
Posted 21 February 2015 - 02:33 PM
unless he told you he removed it - they do get messed up easily
I've had them rott off / fall off in the past - even thou they are pinned on
in addition to ethels post the a series is a smother cast block - the a+ has a ribbed block
post a pick so we can have a look
Remember red ones are faster  ;D
#4 87advantage
87advantage
  • 53 posts
Posted 21 February 2015 - 04:56 PM
Thanks guys looks like a 1275 here is what it looks like
Attached File  IMG_1351.JPG   86.87K   99 downloads
#5 Swift_General
Swift_General
  • 871 posts
Posted 21 February 2015 - 07:01 PM
That's a pre A+
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 February 2015 - 07:06 PM
A picture would be good, but without an engine number or paperwork, the only way to find out for sure is to pull it apart.
Basically from a picture you can tell what the basic engine is, A series or A+, Small or Big Bore but that's about it.
#7 Cooperman
Cooperman
  • 23,225 posts
Posted 21 February 2015 - 09:09 PM
From the photo it is a pre-A+ with a Verto clutch. The distributor aperture is large and the block has no external ribs.
Without a photo of the back of the block it is hard to tell whether it is a 998 or 1275. If it has two cam chest covers on the back, each about 4" x 7" with a centre bolt, then it is a 998. If the back of the block is solid it is a 1275 block.
#8 Ivor Badger
Ivor Badger
  • 846 posts
Posted 21 February 2015 - 09:12 PM
its a 998/1098 head. Looking at the starter = possible metro
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 February 2015 - 09:13 PM
Sorry, didn't realise that the photo was the actual engine.... thought that was just and example photo...
Cooperman, you should know better.... slapped wrist ;)
Two core plugs in the block above the transfer case and it's an A series, it must be a solid wall big bore, other wise it'd have 1 core plug.
It's a right Heinz 57 of an engine... Metro starter motor, A series block, A+ head, Verto clutch
Edited by Guess-Works.com, 21 February 2015 - 09:14 PM.
#10 Cooperman
Cooperman
  • 23,225 posts
Posted 21 February 2015 - 09:29 PM
Well spotted. I didn't notice the core plugs :shy: .
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 February 2015 - 09:35 PM
I didn't notice the picture... lol
#12 87advantage
87advantage
  • 53 posts
Posted 22 February 2015 - 07:02 PM
So I have  "Mini Advantage Special edition Heinz 57 " are these rare !!  more pic of the other side of the engine and the head
Attached File  IMG_1272.JPG   87.28K   50 downloadsAttached File  IMG_1272.JPG   87.28K   50 downloadsAttached File  IMG_1275.JPG   91.49K   19 downloadsAttached File  IMG_1278.JPG   78.15K   21 downloads
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 February 2015 - 07:16 PM
Engine is from an austin 1300 most likely  as it , gearbox is A+, head is fairly standard nothing special
#14 87advantage
87advantage
  • 53 posts
Posted 22 February 2015 - 08:02 PM
Attached File  IMG_1240.JPG   59.81K   2 downloadsAttached File  IMG_1241.JPG   57.11K   2 downloads
Numbers on block and gearbox  do these apply to anything?
#15 Spider
  • 14,742 posts
Posted 22 February 2015 - 10:01 PM   Best Answer
