How can I tell what engine I have in my mini the previous owner has put a different one in and has removed the Engine number plate !
Best Answer Spider , 22 February 2015 - 10:01 PM
Working from the Freeze Plug type, size and number of them the block is a Pre-A+ 1275, no question.
Working from the Thermostat Housing orientation, the Head is also 1275.
Go to the full post#1
Posted 21 February 2015 - 11:31 AM
Posted 21 February 2015 - 11:50 AM
There are some obvious differences:
1275's don't have tappet chest covers and the thermostat housing locates at a different angle on the head. Though you could put a 1275 head on a smaller engine.
Different compression ratios were achieved with different piston crowns - flat or dished...
A and A+ blocks have different fitting for the alternator and distributor....
Posted 21 February 2015 - 02:33 PM
unless he told you he removed it - they do get messed up easily
I've had them rott off / fall off in the past - even thou they are pinned on
in addition to ethels post the a series is a smother cast block - the a+ has a ribbed block
post a pick so we can have a look
Remember red ones are faster
Posted 21 February 2015 - 04:56 PM
Posted 21 February 2015 - 07:01 PM
Posted 21 February 2015 - 07:06 PM
A picture would be good, but without an engine number or paperwork, the only way to find out for sure is to pull it apart.
Basically from a picture you can tell what the basic engine is, A series or A+, Small or Big Bore but that's about it.
Posted 21 February 2015 - 09:09 PM
From the photo it is a pre-A+ with a Verto clutch. The distributor aperture is large and the block has no external ribs.
Without a photo of the back of the block it is hard to tell whether it is a 998 or 1275. If it has two cam chest covers on the back, each about 4" x 7" with a centre bolt, then it is a 998. If the back of the block is solid it is a 1275 block.
Posted 21 February 2015 - 09:12 PM
its a 998/1098 head. Looking at the starter = possible metro
Posted 21 February 2015 - 09:13 PM
Sorry, didn't realise that the photo was the actual engine.... thought that was just and example photo...
Cooperman, you should know better.... slapped wrist ;)
Two core plugs in the block above the transfer case and it's an A series, it must be a solid wall big bore, other wise it'd have 1 core plug.
It's a right Heinz 57 of an engine... Metro starter motor, A series block, A+ head, Verto clutch
Edited by Guess-Works.com, 21 February 2015 - 09:14 PM.
Posted 21 February 2015 - 09:29 PM
Well spotted. I didn't notice the core plugs .
Posted 21 February 2015 - 09:35 PM
I didn't notice the picture... lol
Posted 22 February 2015 - 07:02 PM
So I have "Mini Advantage Special edition Heinz 57 " are these rare !! more pic of the other side of the engine and the head
IMG_1272.JPG 87.28K 50 downloads IMG_1272.JPG 87.28K 50 downloads IMG_1275.JPG 91.49K 19 downloads IMG_1278.JPG 78.15K 21 downloads
Posted 22 February 2015 - 07:16 PM
Engine is from an austin 1300 most likely as it , gearbox is A+, head is fairly standard nothing special
Posted 22 February 2015 - 08:02 PM
IMG_1240.JPG 59.81K 2 downloads IMG_1241.JPG 57.11K 2 downloads
Numbers on block and gearbox do these apply to anything?
Posted 22 February 2015 - 10:01 PM Best Answer
Mini Technical Sections →
Problems, Questions and Technical →
Mk4 - Last Inline Glass Fuse Of Four No Power Running Through It?Started by postve , 26 Aug 2024 electrical, engine |
Camshaft IdentityStarted by Minivabnman , 20 Aug 2024 engine |
Answered
Hs4 Carb Needle Or Wait For Hif44 On A Stage 1 1275?Started by Suburu , 06 Aug 2024 engine |
Answered
Heated ManifoldStarted by ecky , 23 Jul 2024 engine |
97 Mpi Mini Idle Issues - Possibly AicvStarted by JCUSP , 21 Jun 2024 electrical, engine |
