Well my son helped me replace the switch and while we were at it we did the rear quarter window seals. We didn't need to bleed the brakes at all, so thanks for the tips, guys!
#16
Posted 01 March 2015 - 04:51 PM
#17
Posted 22 January 2023 - 09:41 PM
#18
Posted 22 January 2023 - 09:43 PM
Just use the brake banjo bolt as used in later Minis.
#19
Posted 23 January 2023 - 09:13 AM
I used to run a 'P' reg Clubman Estate, first registered in '76..
#20
Posted 31 May 2023 - 11:45 AM
Resurrection: what bolt can I use to delete the pressure switch? I upgraded to a pedal switch and need the space back for an engine swap.
What did you end up doing on yours? I am looking to do the same
Care to link to the right part?
#21
Posted 31 May 2023 - 01:17 PM
Easy to put Banjo into the search box on MiniSpares.
this link will show the banjo bolt and the banjo fitting you have now. And the pressure switch.
http://www.minispare...banjo bolt.aspx
Also tagged with one or more of these keywords: brakes, electrical
Mini Technical Sections →
Problems, Questions and Technical →
1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , Yesterday, 05:46 PM ![]() |
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , 23 Apr 2025 ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
