Another Cg13 Conversion
129 replies to this topic
#106 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
  • Local Club: Snowdon minis
Posted 08 May 2016 - 08:26 PM
Today went well! Had some help which is rare :)
Also got the arch in!
Shortly before hacking chunks out of it again because the arches are getting tubbed.
Had to stop at this stage because my sheet of steel was a few cm to short to make the new section of arch for the tubbing.
I have ordered a longer piece of steel so depending on work I will attempt to get the new section in next weekend.
#107 Baldspeed Racing
Baldspeed Racing
  • 1,204 posts
Posted 10 May 2016 - 02:07 PM
good call on the tubbing makes sense to do it all now. just sorted mine and it was a ******* of a job to do on a fully built up car
#108 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 10 May 2016 - 05:37 PM
I can imagine! Drum brakes, seat backs and the like getting in the way. The way I'm looking at it is if the shell is rust free when I finish the car I will have sealed the hell out of everything, waxoyled everything and pored engine oil down all of the seams from the inside. As well as living in a garage and rarely being driven in wet conditions. Should be fine for years before any body work needs doing. Unless I end up putting it in a wall, but I endeavour to avoid that :)
#109 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 16 May 2016 - 03:05 PM
Got a little bit done last weekend, pretty much completed the arch tubbing, but was zombified because I worked till about 2 in the morning the previous day. Just need to tack the rear quarter onto it and weld the rear bulkhead onto the arch then its the rear bumper lip section of the boot floor.
#110 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 31 May 2016 - 11:45 AM
This weekend this stuff happened
I finished off the arch and started on the boot floor
Unfortunately I have to re build the rear panel lip
And this is where I am up to now.
#111 McMini 22
McMini 22
  • 289 posts
Posted 31 May 2016 - 01:46 PM
Rust.  the enemy of all wee minis!
What are you rust proofing it with?
Have a look at Epoxy Primers as they seam to be the best thing at the moment.
#112 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 01 June 2016 - 10:38 AM
Cheers will do. I have no painting experience at all so would I need to get a spray gun for this?
I may also be getting another mini as well which makes no financial sense at all... I have a problem
Edited by zebigfatman, 01 June 2016 - 10:39 AM.
#113 McMini 22
McMini 22
  • 289 posts
Posted 01 June 2016 - 12:01 PM
Some of the epoxy primers are brush, roller or thin and spray.  I'm using one called jotamastic 87 and I've only sprayed it so far.  Was a bit orange peely so might neet a bit more thinners.
It goes on aluminium so I'm hoping to try it on my engine with 2K gloss silver on top.
#114 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 05 June 2016 - 10:39 PM
Had 4 days off work and I had assistance on 3 of those so the rear panel flange got fully rebuilt and the rear of the boot floor is fully in and the other arch is mostly out!!! So many pictures.
I will be grinding down the edges of the floor and rear panel and seam welding them and the bumper holes to prevent future water ingress as well.
Edited by zebigfatman, 05 June 2016 - 10:46 PM.
#115 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 21 June 2016 - 06:39 PM
Good news! I have bought another mini! Not to sure what its called yet but I think its female. It will also be getting Kelvins rebuilt 1275. Unfortunately driving back from Nottingham was terrifying because the brakes were awful but that will be rectified this week with a disk conversion.
Anyhow I have finished patching the boot floor and welding in the arch. Tomorrow I will start off tubbing the new arch.
#116 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 24 June 2016 - 10:50 PM
Got the other arch tubbed.  :D
Possibly more this weekend.
#117 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 25 July 2016 - 10:59 AM
After getting the other mini I have had quite a bit to sort. Now pretty much finished apart from the future engine transplant and looks like this :)
Due to that I haven't done any work to Kelvin until this weekend. I took out the arch closing panel, braced the rear seat base to the exhaust tunnel, made some modifications to my rear jig whatsit and removed the heelboard which was terrifying :)
Before welding in the new one I want to sort out the holes in front of the rear arches.
#118 thelegg
thelegg
  • 612 posts
Posted 04 February 2017 - 11:17 PM
Any updates ?
#119 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 11 April 2017 - 11:14 AM
Only been doing the occasional bits of work the last few months, in honesty haven't touched it since jan. Broke my phone so lost most of the pics I had taken anyway.
got back on it last weekend and part of the floor is in finally!!!
Over Easter I will be smashing it  because I kind of feel guilty for avoiding an alignment problem with the healboard for so long. All sorted now but was just one of those things that I was dreading doing.
forgot how therapeutic welding is :)
#120 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 15 April 2017 - 06:40 PM
Did a bit yesterday, the reac companion bin area is finished except for a bit of tidying up. Tomorrow the front of the floor might go in or possibly start on the A pillar finally.
