Full Respray Cost?
20 replies to this topic
#1 Liam_96
Liam_96
  • 13 posts
Posted 11 February 2015 - 05:30 PM
Hi, thought id ask incase anyone might know :D
I was just wondering if anyone would know roughly how much a full exterior respray would cost, we have fitted all the panels needed and stripped the car, but just want to know how much roughly it would cost for a prep and respray.
Many Thanks
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 February 2015 - 05:39 PM
Depends where you go and how much prep is required.
For a good job, you will be looking around the £2000 mark but some will be less and some will be more.
It all comes down to the prep
#3 Liam_96
Liam_96
  • 13 posts
Posted 11 February 2015 - 05:47 PM
Good point, i havent got any quotes from anyone yet as they want to see it before, which is fair enough,
but you've cleared alot of things up, as i wasnt sure at all what they would quote me.
Thanks Mate For that :D
#4 Almond-1
Almond-1
  • 203 posts
  • Local Club: Cooper Register
Posted 11 February 2015 - 05:55 PM
The more stripping the cheaper it will be. Obviously painted in two pack paint will be more expensive than cellulose & better.
#5 Liam_96
Liam_96
  • 13 posts
Posted 11 February 2015 - 05:58 PM
Haha true, i dont think theres anything else i cant strip off though :P, ill have too see, hmm yeah, i was thinking two pack paint, but ill have to see the price difference between the two.
#6 FAZ
FAZ
  • 284 posts
Posted 11 February 2015 - 06:01 PM
painted all of mine inside and out, red and white, all in, 3 months prep (weekends and some evenings) £100 on various sand papers and filler, and £250  on paint (2k), result -
1653345_10152484646391213_14266006635397
1454651_10152484650511213_49506961124550
presentable
Edited by FAZ, 11 February 2015 - 06:01 PM.
#7 Liam_96
Liam_96
  • 13 posts
Posted 11 February 2015 - 06:04 PM
wow, thats looks great.
Would you say it would be worth it too spray it myself?
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 February 2015 - 06:08 PM
I would defiantly have a chat with a bodyshop and try to have a look at some of there work. They will tell you pretty quickly after seeing your car how much prep they would need to do
#9 Liam_96
Liam_96
  • 13 posts
Posted 11 February 2015 - 06:14 PM
ive looked around and found some, just gotta look round tomorrow to see the quality of their work, its worth seeing what finish id get with some of peoples work.
#10 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 February 2015 - 06:21 PM
If you are confident with a spray gun and and are not too bothered if it didn't come out brilliantly then go for it.
If it ges wrong, then all you have wasted is a few hundred and some time
#11 Liam_96
Liam_96
  • 13 posts
Posted 11 February 2015 - 06:27 PM
hmm yeah, well ill get some quotes and ill see how much i might cost me, then i can make a decision.
Thanks All For The Help  :proud:
#12 FAZ
FAZ
  • 284 posts
Posted 11 February 2015 - 06:41 PM
wet flatting will sort any runs and overspray if you do ityourself
#13 mk1leg
mk1leg
  • 9,343 posts
Posted 11 February 2015 - 09:17 PM
if you have all the prep done to a high standard then you could have a go yourself......but its the prep that counts...... :highfive:
#14 Alex_B
Alex_B
  • 4,573 posts
Posted 11 February 2015 - 10:18 PM
You CANNOT spray 2k at home, its a highly toxic paint that requires a fully filtered environment, full air fed mask and paint suit. This is due to the paint being Isocyanate based and any exposure to it (breathing it in, through your eyes/skin) can leave you in a&e, or worse.
But spraying at home with celly is possible and a decent job can be achieved but the key is the prep work, generally speaking its 80% prep, 10% masking and 10% spraying.
Otherwise a bodyshop can quote anything between £1k - £3.5k depending on prep and final finish required, flat colours will be cheaper than metallics and exotic paint jobs.
#15 mikep12
mikep12
  • 73 posts
Posted 11 February 2015 - 10:19 PM
Two points for a DIY paint job. For obvious reaons they are usually completed over a long time which can lead to problems. The first is treat ANY rust either surface or pits with a good rust killer, wash and prime as per instructions. Make absolutely sure your primer is water proof as many are not, I can fully recommend Davids Zinc 182. Secondly if using filler on any area do not leave it unsealed as filler will start absorbing water straight away and many otherwise good jobs have been ruined by susequent failure due to damp filler causing rust.
PS do not be conned by the metallic fillers unless you REALLY enjoy rubbing down.
Edited by mikep12, 11 February 2015 - 10:27 PM.
