Mitzi
Posted 08 July 2004 - 09:03 PM
first battle is the rust. I have spent countless warm sunny days sanding it down, treating it, filling where needed and finally repainting. The paint looks patchy where we have had to do it, but at least it is starting to look better. The worst places are apron under/behind front bumper, passenger side door, above the sills and inside left hand front wing. The absolute worst spot was windscreen panel r/h side. It was full of the kitchen roll and kitchen foil. Not very pretty at all.
I have also scrubbed and stripped down the hubcaps. They are now all re-done in silver leaf paint.
We installed a new wiper motor including all the nice chrome bits.
Yesterday I replaced the tie rod end bushes with the help of cowboy.
there is still quite a bit to do, but at least the interior is great and not much engine works needs to be done. will start posting pics soon.
Posted 10 August 2004 - 08:20 AM
Posted 18 August 2004 - 08:58 PM
i have changed both front knuckles, what a job that was, and i have to patch under the drivers floor plate, but only a small bit, and some of the other susspesion bushes look dodgy. that was untiil i started doing the nearside knuckle, then i found out that the nearside engine mounting was f**ked , so she is now safely locked away in my workshop, until i get one..
looks like i can change it in situe, through the inner wing, i hope
Posted 19 August 2004 - 12:18 AM
we still need to replace the front panel and the panel inside the left wing, but we have the spares for that now. will need to be repainted along with the new bonnet and the passenger door ( thank you bluemini) and then it's on with the new bumpers that are sitting in the house waiting to go on. i've also noticed that the heater does not work and i think there is something wrong with the thermostat too which might be why i cant get any heat inside the car.
i really haven't done any work on her at all lately except for keeping it nice and clean and shiny.once the kids go back to school i will have more time.
Posted 20 August 2004 - 07:20 PM
mitzy out :wales:
Posted 20 August 2004 - 10:04 PM
hopefully it will all bo sorted out soon, passes the MOT and we can start again on the bodywork
Posted 21 August 2004 - 08:26 AM
Posted 21 August 2004 - 10:36 AM
Posted 24 August 2004 - 02:37 PM
the rear fog light doesn't work... i didnt know that because i have never used it
Steering rack gaiter.... one is split
and the front end is too rusted out which i knew about since i have been nagging cowboy to fix it for ages. i just never knew it was that bad to fail it
so, cowboy has taken the car back into work to do the work on it. should be interesting having a front end that is british racing green on it and the rest silk green.
Posted 26 August 2004 - 10:20 PM
weld front end onto her tomorrow, and change the steering rack gaiter, fix the fog light and then take her back down for a retest
Posted 27 August 2004 - 02:17 PM
Posted 28 August 2004 - 09:03 AM
to do this i cut away the bottom section, just behind where the bumper sat on the lip and a section of the passenger side inner wing, along with the panel on the drivers inner wing.
i cut the same out of the donnar car i had, plus a litte extra for over lap. then welded it all together, i small bit of body filler over the welds, after they were ground down flat, then primmered.
the final coats of paint will be done when the door is ready for spraying. should be done for MITP
here are some pics
Posted 28 August 2004 - 09:04 AM
Posted 28 August 2004 - 09:05 AM
Posted 28 August 2004 - 09:06 AM
