Replacing Lock Barrel In The Boot Lock.......
15 replies to this topic
#1 hennoir
hennoir
  • 11 posts
Posted 10 February 2015 - 09:36 AM
Hey up - OK, I'm trying to replace the lock barrel in the bootlid in my little mini and i've managed to remove the lock mechanism etc, but falling at the last hurdle...
I can't get the barrel out to replace it. I haven't got the key from current lock, so i'm turningto the guru's.......
Any advice welcomed.......
Cheers Chris
Edited by hennoir, 10 February 2015 - 09:43 AM.
#2 wile e coyote
wile e coyote
  • 1,230 posts
Posted 10 February 2015 - 09:53 AM
Seems you've done everything right thus far - the square'ish lug is the actual lever to cause the lock - looks nicely corroded....but I think the lack of key is the  problem... I think your best option is to drill out the lock (use a significantly undersize bit as there's a fair bit of shrouding in the handle) and then extract the old one piece by piece......wont take too long.....
#3 hennoir
hennoir
  • 11 posts
Posted 10 February 2015 - 10:09 AM
Ok then i'll plug in the drill and get the hammer....I did look at trying to drive the lug out but thought i'd ask before bashing it to death and of course tried lubing it first too...
I take it it does just drive through like the pin?
Cheers for that
Chris
#4 1984mini25
1984mini25
  • 8,784 posts
Posted 10 February 2015 - 11:12 AM
The way I've tended to do it in the past without the key, is you put the handle in a vice wrapped up to protect it and just hammer a screwdriver in to the old lock barrel.
#5 gazza82
gazza82
  • 2,993 posts
  • Local Club: TMF+
Posted 10 February 2015 - 11:19 AM
Sometimes the key number is engraved on the boot handle ... you might get lucky.
But no, it won't come out as the key pulls the five small tags in that operate the lock and they are holding it in place now. Take the key out of your new one and you will see what I mean ..
#6 hennoir
hennoir
  • 11 posts
Posted 10 February 2015 - 11:29 AM
OK cheers guys I will give it a whack with a driver and see if i can free it up ......cheers for your help...
#7 hennoir
hennoir
  • 11 posts
Posted 12 February 2015 - 11:31 AM
Ok further update and assistance needed.........Grrrrrrrrr
I have managed to get the old lock barrel out using gentle persuasion but can't seem to get it all back together.....Ive removed the pin and the square/rectangle lug and removed the barrel and hopefully you can see where i've stopped/got to (pics)
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 February 2015 - 12:46 PM
Your boot lock is much later than that on my car but I assume the design is largely the same.  I anticipate you may have the wrong lock barrel.  There are different styles for door locks, ignition locks, and boot locks and those changed a couple of times over the years.
See the Mini Spares kit linked below.
https://www.minispar...px|Back to shop
(if the link fails, go to Mini Spares and search for their part "BARRELSET"
Look at the barrel in the middle of the 3 shown in the product picture.  You will see the middle barrel has an eccentric post at the bottom.  That post should go into the slot of your boot lock's square pin.  When you turn the key, the eccentric pushes the square pin in and out of the handle assembly to lock the boot.
#9 hennoir
hennoir
  • 11 posts
Posted 12 February 2015 - 11:07 PM
Ah ha - all becomes clear. Yeah you're right I have the wrong barrel. All looks obvious now I've seen the correct part. Cheers for that info, minispares here we come.
#10 hennoir
hennoir
  • 11 posts
Posted 25 February 2015 - 01:39 PM
Ok so i've now replaced the lock but just for closure and future ref ...
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 February 2015 - 03:39 PM
Thanks for posting the update and pictures.
#12 jamesquintin
jamesquintin
  • 1,017 posts
Posted 08 July 2016 - 12:59 PM
thanks for this, has helped me imensly today!
#13 ryomini
ryomini
  • 583 posts
Posted 08 July 2016 - 01:39 PM
Glad you got it fixed
I had a very stiff barrel said the vicar to the actress
and soaked it in vinegar for quite a while then oil and it finally popped out
but I did also have the key
I would add that sometimes soaking in brown or white vinegar can remove enough rust to let bonded parts separate for removal
Your annotations are very good
#14 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 09 July 2016 - 09:43 PM
Your 'incorrect' barrel is an ignition barrel for a Mini with the central ignition switch.
#15 ultimax5
ultimax5
  • 21 posts
Posted 22 October 2021 - 04:00 PM
Just got my boot lock barrelset replaced this evening. This thread was super helpful. Thank you to all who shared tips and especially to hennoir for the pictures.
