Spi Coolant Temp Sensor Replacement
Posted 08 February 2015 - 11:54 AM
What is the best way to get to it ? Inlet off? Or can I get it to it without removing the inlet ?
Any tricks or tips to doing it ??
Thanks Dan
Posted 08 February 2015 - 12:28 PM
inlet off I believe
Posted 08 February 2015 - 12:33 PM
Posted 08 February 2015 - 12:37 PM
Many thanks
Dan
Posted 08 February 2015 - 07:44 PM
It can be done without taking the manifold off but is a bit more fiddly. Drain the system or clamp the two pipes to the inlet manifold. Jack car up and after removing the electrical connector, using a deep 19mm or 3/4 socket with a couple of long extension bars unscrew the sensor, replacement is a straightforward reversal and top system back up. Good luck whichever method you use.
Top bloke did it this way and was a doddle to do
Many thanks Dan
