Painting Rocker Cover
16 replies to this topic
#16 Craig89
Craig89
  • 600 posts
Posted 05 February 2015 - 07:17 AM
I have a tin of brush enamel that has been used to paint the block with. Can this be thinned down and sprayed for things like the rocker cover, timing cover etc?
#17 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 05 February 2015 - 01:33 PM
The short answer is "probably".  As with all painting, prep well and use a compatible primer for the top coat.  Generally enamels thin with mineral spirits and applying a second coat has to be timed "just right" to avoid lifting the first coat.  Practice on a piece of scrap before working on your valve cover.
