Painting Rocker Cover
16 replies to this topic
#1 Georgea2405
Georgea2405
  • 58 posts
Posted 04 February 2015 - 09:25 PM
What paint shall I use?
And any tips when painting it?
#2 willava182
willava182
  • 704 posts
Posted 04 February 2015 - 09:28 PM
Use a high heat paint, and remember to wash white spirit completely out of your brush between coats!
and prep it properly. Sand it down remove and only paint. Might be worth priming it to. (a clear lacquer also looks nice but again high heat!)
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
My rocker cover on my daily was painted with engine enamel out of a rattle can and it's lasting well.
Only one tip when painting parts such as these and that is to thoroughly degrease it strip the whole thing inside and out back to bare metal. so clean that you could eat off of it. Any grease left behind will cause a reaction.
Also take your time building up thin light layers allowing to dry in between.
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 04 February 2015 - 09:29 PM
My engine enamel ?
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 February 2015 - 09:30 PM
My engine enamel ?
Your paint job too IIRC.
Still looks good  :shades:
#6 Icey
Icey
  • 1,551 posts
Posted 04 February 2015 - 09:31 PM
Normal paint will be fine, if it gets hot enough to damage it you've got bigger problems.
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 04 February 2015 - 09:32 PM
My engine enamel ?
I'm surprised, I doubt I prepared it properly.
It'll probably outlast the car.
I like this stuff
http://www.ebay.co.u...=item43d72e9da7
I paint all sorts with it
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 February 2015 - 09:41 PM
It's all coming back to me now. we had it laid out n the floor on a piece of rag and sprayed on another coat and the wind got up immediately and blew a load of dust and dirt on it.
My advice to the OP would be to spray it either inside a garage/shed or wait till it's a calm day
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 04 February 2015 - 10:04 PM
+1 to Icey's comments above.  You do not need high-temperature paint for an engine block or rocker cover.  It simply doesn't get hot enough.
As advised by others above, spend your time properly preparing the rocker cover for the new paint.  Degrease first, then sand as necessary, prime, sand the primer and finally apply the top coat.  Allow that to dry well before handling.  Any shortcuts you take on the prep work will be apparent in the top coat.
#10 Georgea2405
Georgea2405
  • 58 posts
Posted 04 February 2015 - 10:40 PM
So just normal spray paint?
#11 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 February 2015 - 10:42 PM
Yes, that will be fine.
Like has been said, no need for heat resistant paint on a rocker cover.
That said, engine enamel does give a nice finish, it's just not necessary to have a VHT type paint
#12 willava182
willava182
  • 704 posts
Posted 04 February 2015 - 11:04 PM
I disagree, when i painted fine using normal paint it bobbled up in a day's moderate use.
I had possible engine overheating problems at the time by the sound of it.
Better safe than sorry?
#13 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 04 February 2015 - 11:17 PM
No need for HT as said
#14 Shawbags
Shawbags
  • 159 posts
Posted 05 February 2015 - 01:18 AM
Don't brush paint it use a can .
#15 minilee94
minilee94
  • 3,523 posts
Posted 05 February 2015 - 06:14 AM
Mine was painted out of a gun was hammer it's watered down
