I've got a leak from the back of the head on the radiator side, right in the corner. I seem to have had constant oil leaks with this one, first it was the timing chain, so I re did that gasket, then some of the lower ones in the gearbox, then the clutch oil seal, thats had a new seal, and now its leaking out of the head. I was just thinking, what are the chances that the head gasket has been blown all along between a cylinder and an oil way, pressurising the oil and blowing it out of everywhere?
I've got none of the other head gasket failure symptoms, no sludge in oil, no coolant loss and the compression test was within 10% of each cylinder.
Edited by Harrison541, 03 February 2015 - 08:19 PM.
