Jq's '98 Mpi Mini Cooper
589 replies to this topic
#511 jamesquintin
jamesquintin
  • 1,017 posts
Posted 30 October 2020 - 09:12 PM
Got some more time on the shell this week. Quite happy with the progress (albeit slowly) Its starting to looks like a car
Added the plastic clip thing to hole the pipe back:
I ordered some open grommets for the charcoal canister hole, but they were the wring size
I added both window inner seals (after finding the drivers one was the wrong way around)
Took me aaaaaages to get the brake braket on. The hole was slightly too low for the short bolt, so I had to find a longer one to get it in:
Then I got the sound felt back in the roof:
I then set about putting the trim pieces back on:
I added some seam sealer at the top to stop the water getting in (will paint it when dry) and also some Dynax inside the trims
I also started on the sound deadening but ran out of time
That'll do
Q
#512 jamesquintin
jamesquintin
  • 1,017 posts
Posted 06 November 2020 - 10:43 PM
Made a start on finishing off the drivers door. Got the window winder cleaned up and new putty on:
Was a bit of a faff but got it in eventually! Also added the strips either side of the glass. All fits nice a tightly and no bowing of the door skin
Then I popped the Rivnuts in for the wing mirrors
Just a test fit for now as they'll get in the way
I then finished off adding the trim under the rear screen (excuse the rough cutting!) and put the carpet and speakers in
I also put the headlining in to help get the creases out
Put the battery cable in
(Still need to screw/clip it in properly)
and stuck the numberplate on for good measure!
Q
#513 shough
shough
  • 196 posts
  • Local Club: N/A
Posted 07 November 2020 - 09:56 AM
What are the wires hanging down into the boot between the speakers?
#514 jamesquintin
jamesquintin
  • 1,017 posts
Posted 07 November 2020 - 01:05 PM
I've added a run from the central locking and the interior light circuit. I'll be adding a bracket to lock the boot when the doors lock, and also an interior boot light
Q
#515 jamesquintin
jamesquintin
  • 1,017 posts
Posted 20 November 2020 - 09:42 PM
Back to the lockup!
The shell was lacking in paint in the companion boxes (I should have done a better prep in that area), so got some brushable Zinc 182 and got them covered:
Will get some seam sealer and blue paint in there too at some point
Most of the components on the car are 'sort of' on. Nothing is really torqued up or actually finished, so I'm trying to go round each corner and get stuff sorts. The rear brakes needed attention as I'd built them up without greasing any of the surface...
Couldn't resist putting the Cooper wheel badges on!
I also got the Red S badges on front and back:
I reaaaaallllllllly like having an 'S'
Q
#516 jamesquintin
jamesquintin
  • 1,017 posts
Posted 06 December 2020 - 07:25 PM
Back to it this week. Mostly working on the wiring and interior:
Front loom in:
Its not all routed properly, but at least its half in!
Next it was the companion bins. I put some of the brush-able sealant on and got it painted with some leftover blue paint:
I then got going on the foam pads under the arch covers. It didn't have them originally, but it always felt a bit too hard under there, so I used ones from Newton. They needed quite a lot of trimming to fit:
And then on with the arch liner (could only find one, god knows where the other is)
Popped the trim in:
and then went to town with the rust proofing in all the box sections:
Then for a laugh put the rear sets in:
Q
#517 jamesquintin
jamesquintin
  • 1,017 posts
Posted 30 December 2020 - 07:20 PM
Managed to get a whole hour and half on the car in December
Got some little jobs done. Washer pipe is plumbed in:
Interior light wiring is fed through so can do the headlining soon:
Got the lower dash rail stuck in:
and the switch panel bolted up:
Also made a start on the rear belts and got the tensioners in:
JQ
#518 jamesquintin
jamesquintin
  • 1,017 posts
Posted 02 January 2021 - 06:59 PM
Tiny bit more done!
Tidied up some of the dashboard wiring:
SOrted out the bulkhead foam:
And more or less finished up the drivers side seatbelts:
Q
#519 Junior Mini
Junior Mini
  • 313 posts
Posted 02 January 2021 - 07:29 PM
Looking Good  :D
#520 Alice Dooper
Alice Dooper
  • 391 posts
  • Local Club: Minis in Northern Ireland
Posted 03 January 2021 - 12:49 PM
Looking great.  The MPI Rover wiring is a total birds nest behind the dash and in the engine bay.  It’s pretty difficult to make it look decent, especially if your a bit OCD like me.
I think I remember that you’re putting in a heated windscreen, where are you putting the switch or are you using the heated rear window switch to do both?
also noticed that you went back to the original Rover manifold instead of the S LCB, apart from the sensor being in a more sensible place, are there any other advantages?  Reduced noise?
#521 jamesquintin
jamesquintin
  • 1,017 posts
Posted 18 February 2021 - 10:34 PM
Using a new switch for the front screen with a timed relay
Using original LCB mainly for easy of use. The aftermarket LCB's just rust solid and I've always had to saw them off!
#522 jamesquintin
jamesquintin
  • 1,017 posts
Posted 18 February 2021 - 10:39 PM
Hurrah! After 2 months I've got back to the car. Only had a few hors so just did some bits and bobs.
Got the wiring on the right hand side sorted:
Got one new shock in:
and the rear bumper, not forgetting the plastic bits on the end:
Annoyingly the rubber grommet on the brake lever wouldn't sit flush, so had to take the servo bracket off:
Also got the windscreen wiper assembly in:
Fusebox in:
That'll do!
Q
#523 jamesquintin
jamesquintin
  • 1,017 posts
Posted 12 April 2021 - 09:12 PM
Been away from this for far too long! Cracking along now
First thing to investigate is the oil leak. Its waaaaay too bad to leave.
After posting this pic and asking on Facebook, it was pretty obvious what I'd done wrong...
No oil seal on the selector shaft! So i fixed that:
But unfortunately its still leaking (although not as much). Its now coming from the diif side cover, so that will have to come off and get a new gasket/sealant.
Got the handbrake started, and added this extra piece of foam to help stop the cable rubbing on the body.
SPotlight brakcets in:
Headlight electrics connected
Heat shields added (yes I know they are dirty)
Brakes plumed in
One headlight:
New foam added to sills
Rear loom taped in
all the sound deadening in
Finished off the offside rear pcokets
Thats most of the rear done!
Then to start the headlining...
Popped the carpet in for a laugh
Coming along nicely!
Q
#524 jamesquintin
jamesquintin
  • 1,017 posts
Posted 13 April 2021 - 05:57 PM
More work on the motor.
I managed to do over 20,000 miles last year in my dads car (which i've borrowed since I started this restoration) so decided to get my own car! Went for something familiar....
Don't hate me! Needed something reliable to pound the motorways with.
Anyway, back to our original programming. Today was mostly engine bay. A lot of the stuff was in, but just not tightened up. So went around and just got as much done as I could:
Doesn't look like much has changed, but I've done a whooooooollllllllleeee lot of work under there!
Q
Edited by jamesquintin, 13 April 2021 - 05:57 PM.
#525 johnR
johnR
  • 2,297 posts
Posted 13 April 2021 - 07:29 PM
Looking good - I find sunshine always encourages progress!
