Jq's '98 Mpi Mini Cooper
589 replies to this topic
#451 jamesquintin
jamesquintin
  • 1,025 posts
Posted 05 June 2020 - 07:11 PM
well got some big stuff done this week!
My parts for the primary gear turned up from sommerford, so got cracking with that:
Original
New one
After fitting got me bang on 4thou! (I also used two feeler guages)
I used the seal fitting tool from Minispares and got the primary gear seal on and dust cover fitted
Clutch on an tourqed up
Then put it all back together!
I then realised I hadn't knocked the lock tabs down on the main nut so had to take it all apart....
After fitting it back i had forgotten to put the thrust top hat on! On and off it went again....
Anyway, not the engine was complete I wanted to put it inside the subframe, as I intend to lift the body over it when it comes back from the paint shop. The engine is on wheels, so I had to make another block for it to sit on. That meatn sliding it off, putting the subframe on the wheeled trolley, then sliding the engine back on it.... Easier said than done.
Engine mount bolts in and subframe attached!
Popped the radiator on for a laugh
That'll do!
Q
#452 jamesquintin
jamesquintin
  • 1,025 posts
Posted 07 June 2020 - 12:57 PM
I wanted to turn the engine over to see if I've actually put it back together correctly, so I filled it up with oil and got cracking!
I attached the oil pressure guage to make sure thats ok
I charged up the old battery overnight, but its pretty much dead now (was going to replace when car is done anyway) so had to use another car to turn the engine over:
Oil pressure took a while to come up, but eventually sat where it should do (halfway around the dial). I just did a compression test on one of the cylinders and it was fine.
I also found a small leak, which is easily fixable :)
I pushed the engine back in the car ready for when the shell comes back!
Q
#453 fokko
fokko
  • 196 posts
  • Local Club: Mini Seven Club Nederland
Posted 08 June 2020 - 07:56 AM
What treatment did you use for the gearbox/transfer case/clutch cover? It looks great! If I read it correctly, it was blasted using glass or soda, right? And did they get some protection afterwards?
#454 jamesquintin
jamesquintin
  • 1,025 posts
Posted 08 June 2020 - 09:52 AM
https://www.tsrvapourblasting.co.uk/
Nice bloke in Kent. No treatment to it yet...
Q
#455 fokko
fokko
  • 196 posts
Posted 08 June 2020 - 10:50 AM
Thanks! I'll take a look if I can find similar services in my area. Are you planning on doing a treatment to it?
#456 jamesquintin
jamesquintin
  • 1,025 posts
Posted 13 July 2020 - 08:14 PM
whoa. Long time not working on the car. Had some changes in personal circumstances, so build is taking longer than I wanted...
Anyway, got the wheels back form eh powder coaters (MaxPowder in Hemel), they look great!
Will dress the walls when the car is finally ready. Hopefully start rebuilding the shell in the first week of August...
Q
#457 fokko
fokko
  • 196 posts
Posted 14 July 2020 - 06:29 AM
Wheels look fabulous! Is your shell already back from paint?
#458 jamesquintin
jamesquintin
  • 1,025 posts
Posted 15 July 2020 - 08:03 AM
Nah not yet, taking the engine down there next Friday. Hopefully it'll be in primer
Q
#459 jamesquintin
jamesquintin
  • 1,025 posts
Posted 17 July 2020 - 08:43 PM
Bit  more done today. The grease in the ball joints had gone off, so stripped them down and re-did them. I then set about building the hubs back up:
I was a bit worried about the callipers not fitting inside where the wheel weights were, but they are fine:
Plenty of space!
Q
#460 jamesquintin
jamesquintin
  • 1,025 posts
Posted 24 July 2020 - 12:24 PM
Went and visited the shell, looks good to me so far!
Had a little issue with the engine.... When it was in the van it fell over! Basically fell backwards onto a plastic box, which broke the fall. Couldn't see any damage, so hope its fine internally...
Q
#461 I hate Brian
I hate Brian
  • 782 posts
Posted 26 July 2020 - 10:11 AM
Looking good James what colour you going for ?
#462 Dutchdave's25
Dutchdave's25
  • 105 posts
Posted 28 July 2020 - 07:16 AM
 I bet its going to be original :P (the original colour I mean)
Edited by Dutchdave's25, 28 July 2020 - 07:17 AM.
#463 I hate Brian
I hate Brian
  • 782 posts
Posted 28 July 2020 - 08:57 AM
Bet you can't wait whens it actually in for paint ?
#464 jamesquintin
jamesquintin
  • 1,025 posts
Posted 28 July 2020 - 04:37 PM
Of course its going to be original! ;)
Q
#465 jamesquintin
jamesquintin
  • 1,025 posts
Posted 10 August 2020 - 09:54 PM
Its got some paint on it! :)
Q
    Bing (1)
