Jq's '98 Mpi Mini Cooper
589 replies to this topic
#406 jamesquintin
jamesquintin
  • 1,017 posts
Posted 25 April 2020 - 07:01 AM
Project is looking brilliant so far.
1) Seen you still have a stock manifold on your S Works conversion.  Did you keep the original because of the better location of the O2 sensor?  I don't think the Manifold LCB that comes with the kit does a lot, did you notice anything different?  Must admit, I'd like the idea of a heat shield between my manifold and the induction system - had a very minor heat issue causing difficulty starting when a hot engine was causing evaporation when I was waiting for a ferry last year.
2) Could you share your file with the stickers please?  My wife has a fairly fancy printer that can cut as well - I've a file for a stone chip guard for the rear wheel arch.  Has a set on mine for 4 years now and they're still just about invisible.  Will send a set if you want.
3) Seen you putting a sticker on a fuel pipe that looked as if its original - are you going to use the fuel pressure regulator from the S kit again?  I love mine, gets me through MOT nicely and keep a screwdriver in the car for the journey home afterwards.
Loving your work.  Loved your Youtube video on your S conversion too.  Studied it well before I fitted mine.
Thanks.
1 - Had the LCB on when I did the conversion, but they go rusty which makes it difficult to get off at a later date. I could also never get them to seal up properly and it would blow, so decided to go back to factory as I read it didn't make much difference, and I could just bolt it up.
2 - Will DM you
3 - That fuel pipe is the one on the right that you keep, its the lest hand side that is removed during the conversion
Q
#407 jamesquintin
jamesquintin
  • 1,017 posts
Posted 25 April 2020 - 07:04 AM
Had a tidy up of the garage and got the shell out in the sun and removed all the stuff i'd been storing in it:
Still doing some work on the electrics and need to sort this lot. WIll be adding the remote central locking, heated front screen, stay on interior light and headlight door buzzer:
I'm also still going sticker mad! Replaced the manky ones on the speakers:
Q
#408 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 25 April 2020 - 07:43 AM
I do like the detail you are going into with your project, refreshing the stickers is a nice touch.
With that said, on the speaker sticker there is a slight mistake. Where you have 4n it should be 4 Ω (ohm).
I know it is being picky, but going through your thread you are quite meticulous with the details, and I think you would rather it was right.
Keep up the good work so far, it is interesting to follow along.
#409 jamesquintin
jamesquintin
  • 1,017 posts
Posted 25 April 2020 - 07:51 AM
ahhhhhh Wondered why there was an odd shaped N ;) Will fix!
Q
#410 jamesquintin
jamesquintin
  • 1,017 posts
Posted 25 April 2020 - 06:47 PM
Carpet day today. I'm sure most of us have broken plastic seat runners on the carpet. That just won't do! I got the replacement from Newton Commercial. The old carpet needed a bit of work. I stuck some of the underlay back as well as the plastic that protects the rear loom that runs along the floor:
The old runners are quite easy to pull off as they had gone rusty!
Started putting them in. They use split rivets, so you have to knock them in from the back. I used a punch I have to get the pins apart and then finish with the hammer. I also put a bit of gaffer tape on the back to cover the bare pins
Much better! And just for a laugh I put down the Cooper floor mats I got ages ago but never put in the car:
fPsuppe.jpg?1
#411 leepol83
leepol83
  • 1,744 posts
Posted 26 April 2020 - 03:41 PM
Loving this build ?? Top work Q keep em coming, one question can you post up some measurements of the rubber that fits under the fuel tank, doesn’t look like you can buy them anymore
Cheers ??
#412 leepol83
leepol83
  • 1,744 posts
Posted 26 April 2020 - 03:42 PM
Double post ?‍♂️
Edited by leepol83, 26 April 2020 - 03:43 PM.
#413 jamesquintin
jamesquintin
  • 1,017 posts
Posted 30 April 2020 - 04:48 PM
Been off this for a couple of days, but had a Minispares delivery today (hurrah!)
I've been giving the engine loom a clean up and fixing one or two bodges:
This sticker was manky, so obviously I made a new one!
I was also missing the clip to hold the loom to the air filter bracket. Its right in the centre as yo open the bonnet and its always annoyed me it wasn't there. So fixed that
Could still do with a bit more cleaning :)
I got some new covers for the track rod ends so started putting those on:
That'll do for today. Fixing the camshaft timing for good tomorrow :)
Q
#414 jamesquintin
jamesquintin
  • 1,017 posts
Posted 02 May 2020 - 09:37 AM
back to the engine. Got myself the 2deg woodruff key, so popped that on and checked the timing:
Kept coming out at 109deg! Tried it the other way around and same result!
I ended up sandpapering the bottom curve it it so it sat better in the camshaft slot. After I did that the timing came out at 106.5deg, which is fine for the cam (according to Swiftune)
Next bit to go back on was the rockers. They were in a plastic box, but some how it was covered in bots of dirt. I stripped it down, clean it up and then got it on the car:
Just need to set the tappet clearance and get the timing cover and other bits back on
Q
#415 MaximMini
MaximMini
  • 226 posts
Posted 03 May 2020 - 06:45 AM
Hi James,
Quick question. If you redo your stickers, do you print out pictures you took or found somewhere in the internet? Or do you do them from scratch, doing the writing letter by letter?
Love your incredible details.
Cheers,
Christian
#416 jamesquintin
jamesquintin
  • 1,017 posts
Posted 03 May 2020 - 04:40 PM
Hi James,
Cheers,
Christian
All done from scratch! Will be putting them on eBay soon
#417 jamesquintin
jamesquintin
  • 1,017 posts
Posted 03 May 2020 - 04:45 PM
back to the engine. I finished doing the valve clearance (well started from scratch really) and then cracked on with putting all the bits back on properly and not just for show...
I noticed my new alternator didn't have a sticker on it. I went back into my archives and found a pic of the engine bay from when I had it (almost) new:
The sticker is a different shape from the ones from other sellers, so I did a shout out on FB for any close up pics of an original one (thanks to those who sent me them!) and I re-designed a new one and printed it off:
p0D09lf.jpg?1
Looks the bee's Knee's! Again these'll be on eBay soon
Q
#418 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 May 2020 - 08:47 PM
Look forward to seeing the stickers for sale.
Will you be selling them as complete car days?
Ben
#419 jamesquintin
jamesquintin
  • 1,017 posts
Posted 04 May 2020 - 06:23 AM
Ben
I sure will! Getting my head around eBay properly as I've never really sold things like this before. I've got the alternator one on there now:
https://www.ebay.co....em=153918088863
Q
#420 leepol83
leepol83
  • 1,744 posts
Posted 04 May 2020 - 09:19 AM
Ben
Q
Brilliant and a good price too ??
