Jq's '98 Mpi Mini Cooper
589 replies to this topic
#391 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 17 April 2020 - 06:37 PM
Looking great?
#392 jamesquintin
jamesquintin
  • 1,017 posts
Posted 19 April 2020 - 10:34 AM
So on with the timing. Got the dial on and following the MiniMania youtube video the cam is at 109deg when it should be 107... Will have to order a 2deg woodruff key to sort it out  O_O
Got the oil pump in and torqued up. I cleaned up the threads on the bolts and added some locktight.
I decided to actual start putting stuff on the block as I can't carry on with the timing end or clutch (the primary gear is with Guessworks)
Head on and fingertight bolted down
And the oil pressure switch/temp/relief valve
Q
#393 Steve220
Steve220
  • 5,038 posts
  • Local Club: BMC
Posted 19 April 2020 - 10:56 AM
I'd get your filter on too whilst you're at it. Will stop detritis getting in to the oil gallery and smashing those new bearings.
#394 jamesquintin
jamesquintin
  • 1,017 posts
Posted 20 April 2020 - 04:20 PM
Annoyingly I haven't got one, that'll be in the next Minispares order...
Moving along, I washed some of the ducting and plastic parts:
And mad a start cleaning the old double sided tape off the rubber that sits under the fuel tank:
Then decided to start bolting all the bits back on the engine. One to see if I had lost any parts, and two, I just wanted it to look cool
God I can't wait to get it all properly done!
Q
#395 Dutchdave's25
Dutchdave's25
  • 105 posts
Posted 21 April 2020 - 09:34 AM
Looking good James, don't forget to mount your lower steady rod bracket. I forgot to mount mine and had to mount it with the engine in the car.. and have an oil leak now.. pfff.
( i just assumed you have the same bracket on a mpi engine )
#396 jamesquintin
jamesquintin
  • 1,017 posts
Posted 21 April 2020 - 11:26 AM
Good shout, will do!
#397 jamesquintin
jamesquintin
  • 1,017 posts
Posted 21 April 2020 - 07:48 PM
So, lower steady bracket on!
I started drilling out the manifold for the heat shield bolt, but none of my drills will touch it :(
Have ordered some new drill bits.
I decided to carry on with some of the stickers I was making. I got some nice glossy vinyl sticker paper and got designing!
I think they look pretty good :)
Q
#398 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 April 2020 - 08:09 PM
Ace!
#399 Bobbins
Bobbins
  • 1,484 posts
Posted 21 April 2020 - 08:54 PM
Q
James, have you painted the gold parts yourself or are they new cadmium plated parts? Very impressive!
Stu.
#400 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 22 April 2020 - 04:50 AM
Love the stickers great detail
#401 jamesquintin
jamesquintin
  • 1,017 posts
Posted 22 April 2020 - 05:58 AM
Q
Stu.
I got all the parts plated by a local company. They were pretty terrible service and quality wise, so can't recommend them...
Q
#402 GraemeC
GraemeC
  • 7,435 posts
Posted 22 April 2020 - 06:04 AM
I’ve got to ask as I’m an arse - were the spelling mistakes on the original stickers?
#403 MaximMini
MaximMini
  • 226 posts
Posted 22 April 2020 - 06:30 AM
Hi James,
Your stickers really look great. I had a good laugh though as you got the spelling wrong on the German writing. Any support needed just let me know.
Christian
#404 jamesquintin
jamesquintin
  • 1,017 posts
Posted 22 April 2020 - 07:03 AM
Hi James,
Christian
Yes there are a fair few mistakes to correct (unless they made a mistake on the original warning label! ;) )
Q
#405 Alice Dooper
Alice Dooper
  • 391 posts
  • Local Club: Minis in Northern Ireland
Posted 23 April 2020 - 08:22 AM
Q
Project is looking brilliant so far.
1) Seen you still have a stock manifold on your S Works conversion.  Did you keep the original because of the better location of the O2 sensor?  I don't think the Manifold LCB that comes with the kit does a lot, did you notice anything different?  Must admit, I'd like the idea of a heat shield between my manifold and the induction system - had a very minor heat issue causing difficulty starting when a hot engine was causing evaporation when I was waiting for a ferry last year.
2) Could you share your file with the stickers please?  My wife has a fairly fancy printer that can cut as well - I've a file for a stone chip guard for the rear wheel arch.  Has a set on mine for 4 years now and they're still just about invisible.  Will send a set if you want.
3) Seen you putting a sticker on a fuel pipe that looked as if its original - are you going to use the fuel pressure regulator from the S kit again?  I love mine, gets me through MOT nicely and keep a screwdriver in the car for the journey home afterwards.
Loving your work.  Loved your Youtube video on your S conversion too.  Studied it well before I fitted mine.
Thanks.
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
