Jq's '98 Mpi Mini Cooper
589 replies to this topic
#331 jamesquintin
jamesquintin
  • 1,025 posts
Posted 08 March 2019 - 07:55 PM
so back to the dashboard. I got some veneer bits from ebay (about £4) so set about cutting the bad parts out of the dash, and making pieces to fit. I've tried to use the knots and cut aroudn them to hide the join:
Have stuck them down and clamped them together. Hopefully it'll work!
I have also had some more parts back from the powder coating. Annoyingly they powder coated the hinges when I asked them just to blast them, so they are stuck fast! He's said he'll take them back and fix 'em
I set about rebuilding the servo. I didn't buy a replacement kits as that was £60, so hopefully it'll be ok:
And I also finished the welding on the door:
That'll do for today!
Q
#332 jamesquintin
jamesquintin
  • 1,025 posts
Posted 10 March 2019 - 07:37 PM
Decided to take a stab at getting some bits put on the front subframe as I just wanted to build something easy for a change!
One cleaned and powdercoated subframe and a bag 'o bits from Minispares:
Bump Stops:
Front brake pip clips:
Cleaned and painted front brake pipe:
top and bottom arms loosely fitted:
Had a bit of an issue fitting one of the arms as the rubber was too tight. Just lightly sanded the rubber and its fitted!
One side done:
and as much as I can do this weekend:
These lock nuts are just too deep, so will swap for normal nuts:
Also added the engine mounts to the gear box and clutch ends:
Then I got the rear subframe down and made a start on that:
Just added the tape on the ends (as per factory)
Will try and make the rear brake pipes next
Q
#333 blueovalcraig
blueovalcraig
  • 193 posts
Posted 12 March 2019 - 11:34 AM
Fantastic work. Soon be finished!
#334 jamesquintin
jamesquintin
  • 1,025 posts
Posted 20 March 2019 - 06:28 PM
Been workgin nights at F1 covering the Australian race, so have had no time to work on the car! Finally got over the jet lag (I didn't even go to oz!) so got into the garage today.
Started slow with cleaning up the threads on thre rear subframe:
Then got on with making the rear brake pipes:
and got them sprayed:
Cleaned up the 3 way brake union:
and fitted:
0449xEa.jpg?1
Also made a start on the front to rear pipe. This bit goes over the subframe to the rear union:
That'll do for now!
Q
#335 pete l
pete l
  • 1,537 posts
Posted 21 March 2019 - 02:37 PM
and fitted:
0449xEa.jpg?1
That'll do for now!
Q
No it won't, we want more.
#336 Steve220
Steve220
  • 5,143 posts
  • Local Club: BMC
Posted 21 March 2019 - 03:20 PM
Nice to see you've done things modular! It makes re-assemble SO much easier!
#337 jamesquintin
jamesquintin
  • 1,025 posts
Posted 22 March 2019 - 05:22 PM
You want updates? I'll give you updates!
Does adding washers to a pipe constitute an update...? ;)
Took a trip to Minispares yesterday and got some bits and bobs. Mostly washers. Cleaned up the brake union for the front and put that on me new pipe:
and added the other side:
I stripped down the track rod ends and got htem primed. Will replace the covers with the new poly ones Minispares have
I'd made a start on the clutch pipe, so needed to put the other bits back on to get it made up properly:
Not sure if you can spot the mistake... The pipe is too tall and fouls the relay pack connectors!
Quite glad I put the servo bracket back on (just to see what it looks like really) as I would have made the pipe up thinking it was fine, and only discover the problem when I finally put everything back in. Shortened the curve and all was well:
Will get that painted green too
Got some new quadrants and gave them a coat of laqure. No idea if that will stop tarnishign, but I'll give it a go
Will get them all fitted up properly soon.
In other news I'll have to be moving house soon, so need to pull my finger out and get the blooming thing finished!
Q
#338 pete l
pete l
  • 1,537 posts
Posted 22 March 2019 - 06:12 PM
Thanks. And yes they are all considered updates.
#339 jamesquintin
jamesquintin
  • 1,025 posts
Posted 23 March 2019 - 04:27 PM
More bits and bobs done. Cleaned up the subframe front pins and gave them some lacquer:
Repainted the subframe mounts as they had started to rust already!
also touched up the paint on the Radius arms and the drive shafts:
and painted the track rod ends (still need new covers)
I also cleaned up the clutch plunger and fitted a new release bearing:
The pins are all pretty worn so will order new ones:
I also cleaned up the rear lights with new seals and foam:
And popped them on the car for a laugh! Not sure the light->body rubber is quite the right shape...
That's it for today!
Q
#340 jamesquintin
jamesquintin
  • 1,025 posts
Posted 24 March 2019 - 05:47 PM
Got the rear subframe pretty much finished off. Not goign to put the radius arms on until its back on the car as it'll just be too heavy to move:
I then got the front-rear brake line done:
That'll do
Q
#341 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 25 March 2019 - 07:44 AM
Really coming together now!
#342 jamesquintin
jamesquintin
  • 1,025 posts
Posted 26 March 2019 - 06:44 PM
Some small updates. I need to get the body ready for painting soon (hopefulyl in a month) so getting on with all the little bits I've bene putting off. Got the nearside wheel arch holes drilled:
I then drilled the holes for the companion bin liners:
I had to trim the passenger side one a bit to get it to sit flush. It's also slightly cracked around the screw hole, so will need to patch that from the back
I then turned my attention to the bonnet. I've not touched it at all since i started the project. There was some rust around the front lip, so have made a start on cleaning thatup
I also cleaned up the spring/catch and will attempt to get a better fit on the front
Thats it for today!
Q
#343 jamesquintin
jamesquintin
  • 1,025 posts
Posted 01 April 2019 - 01:45 PM
Not much of an update, but the engine block has come back from the engneering shop, Just need to clean it up a bit and start building when the body goes away for spraying
Q
#344 jamesquintin
jamesquintin
  • 1,025 posts
Posted 05 April 2019 - 07:22 PM
Floor time! In my effort to get the body ready for painting, I've cleaned up the floor, sanded it down and got it primed. This is just to get the floor ready for the sound deadening panels. I'll be spraying a colour topcoat on to seal the primer:
Q
#345 jamesquintin
jamesquintin
  • 1,025 posts
Posted 24 April 2019 - 10:17 PM
Been off this for far too long. House move is getting in the way!
Got my steering wheel back from the menders:
Pretty happy with that!
Q
    Bing (2)
