Jq's '98 Mpi Mini Cooper
589 replies to this topic
#256 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 October 2018 - 12:24 PM
well done Q.
Looking ace.
Love the sticker. Not sure mine has one but I may need to copy that  :shifty:
thanks. I imagine it would have done. What are the labels like on your loom? I'm going to recreate all the ones you can see in the engine bay and boot but mine are too faded to copy. If your writing is still eldable, can you take some close up pics? I'll send a copy in the post to you ;)
I'm 'almost' ready to make the sound deadening panels too if you are still after a copy?
Q
That sounds good to me Q.
Ill get the loom out and have a look.
Ben
#257 jamesquintin
jamesquintin
  • 1,017 posts
Posted 16 October 2018 - 03:48 PM
Bit more filling and spraying today:
Got the holes for the door bits drilled
And managed to find some paint that almost matches the original green for the brake lines! It's Halfords 'Camouflage Green' with  glossy topcoat. Can't really see it in the pics
Q
#258 jamesquintin
jamesquintin
  • 1,017 posts
Posted 20 October 2018 - 03:54 PM
more progress. Been fiddling with the labels for the wiring loom that are visible. Thanks to Ben_O for providing reference pics, I recreated them. I'll be selling a sheet for the MPI if anyone is interested...
Currently adding a negative cable for the boot light thats going in. Took the tape off and added the cable up to the connector for teh boot switch. Need some thicker sleeve for both cables though.
Then I turned my attention back to the sound deadening panels. Got a load from a supplier in Oxfordshire. Not sure its quite the right product as it won't worm to the curves as well, but hopefully should do the job.
I cut it by hand to match the original. First up was to prep the area, and add the floor bungs as before:
e22QhVN.jpg?1
ZMYc8EV.jpg?1
rgRc7R9.jpg?1
Thought I'd add in a before pic.
Looks ok so far...
Q
Edited by jamesquintin, 20 October 2018 - 04:02 PM.
#259 Chris M
Chris M
  • 167 posts
Posted 20 October 2018 - 07:16 PM
Must say James I’m loving this resto. Your attention to detail is great & the pictures so good showing everything.
Keep up the great work?
#260 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 October 2018 - 09:44 AM
What did you use to form the sound deadening into the grooves?
I find that if you warm the pad with a hot air gun to soften it, then you can form it into the groove with the handle of a large screwdriver. I have one with a smooth rounded handle that is perfect for the job.
I suppose a teaspoon might work too?
Looking great though. Perhaps you could let me know where the sound deadening came from. Looks just right.
Ben
#261 pete l
pete l
  • 1,368 posts
Posted 21 October 2018 - 10:47 AM
I would have put the sound deadening on after painting. Primer paint is porous and sound deadening is not going to make it water tight.
#262 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 October 2018 - 11:25 AM
When I do mine, I'm going to prime the shell in a tinted epoxy matched to the colour of the factory primer and then lay down the pads and paint over the top so looks factory.
I know nobody will be able to tell if there is paint underneath or not but i guess i'm just anal :lol:
#263 ryomini
ryomini
  • 583 posts
Posted 21 October 2018 - 11:52 AM
admiring the hard work
#264 jamesquintin
jamesquintin
  • 1,017 posts
Posted 21 October 2018 - 04:21 PM
Yeah, this one was a test as I'm impatient ;)
Q
#265 jamesquintin
jamesquintin
  • 1,017 posts
Posted 21 October 2018 - 04:28 PM
Ben
It's this stuff:
http://www.soundserv...ping-sheet.html
Not quite as thick as the original, and not 'quite' wide enough for the templates I've made, so will have to adapt slightly. I don't think its bitumen either. Very easy to cut with a Stanley knife though!
I just used my big strong hands to mould it into the grooves, but have bought a seam roller form B&Q to help with the next lot
Q
#266 rossul.burn
rossul.burn
  • 284 posts
Posted 21 October 2018 - 07:08 PM
Looks ok so far...
Q
I love the before and after pictures. It just shows how far the car has come. I have all my before pictures, just need to get the after ones done. Not long till the respray then?
Were you able to get the measurement of the spit by the way?
Edited by rossul.burn, 23 October 2018 - 02:48 PM.
#267 jamesquintin
jamesquintin
  • 1,017 posts
Posted 22 October 2018 - 05:34 PM
AGGGGGHHHHHH
SO fed up today. Hired the stud welder and it doesn't bloody work properly. Got 5 of the studs on but the rest just 'pop' and the hire place is closed until tomorrow so i can't ring them. WHY CAN'T LIFE BE EASY?
Will ring them in the morning and hopefully sort it out
Q
#268 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 October 2018 - 10:20 PM
The earth needs to be clamped as close to where you are welding the studs to as possible to work correctly.
|I wonder if that's why you are having issues?
#269 jamesquintin
jamesquintin
  • 1,017 posts
Posted 23 October 2018 - 06:49 AM
I think the clamps are dodgy. Will take the cable off and clamp directly to the body.
Have had them close and far away with same inconsistent results. One stud worked fine, moved the gun 4inches (perpendicular to earths so same relative distance) and then nothing ?
Q
#270 jamesquintin
jamesquintin
  • 1,017 posts
Posted 23 October 2018 - 08:59 AM
SOLVED!
Turns out I was using the wrong studs. They needed a small pip at the bottom to created a space for teh arc to jump across. Changed studs, worked perfectly!
Trial fitted all the pipes, covers, heat shields and all fits nicely. Turned the shell over and tried the subframe to make sure there was still clearance to the fuel pipes and all good.
Next up is to take the car off the spit, move it out the garage and have a damn good tidy up before starting on the door skins and bonnet
Q
