Jq's '98 Mpi Mini Cooper
589 replies to this topic
#181 jamesquintin
jamesquintin
  • 1,025 posts
Posted 04 June 2018 - 06:19 PM
Not much more done. Got both the rear brake drums painted as well as the adjustaride trumpets:
I then tried welding the radius arm pipe brackets to the arm. It didn't work. Turns out there's a reason they don't weld them at the factory! Will have to drill out some holes for teh studs and see if I can bang them in:
Q
#182 whiskymac
whiskymac
  • 247 posts
Posted 04 June 2018 - 08:20 PM
Awesome thread, just read the whole thing!
You make it all look very easy, which gives me some hope. I've got another project to do which is my brothers, will need loads of welding and it's a bit overwhelming just thinking about it.
Look forward to seeing how this turns out.
#183 jamesquintin
jamesquintin
  • 1,025 posts
Posted 05 June 2018 - 06:02 PM
Thanks man, its overwhelming just doing it!
Did a lot of drilling today. Nothing scarier than drilling into new metal, but has to be done. I decided to use some rivnuts to hold the grill on, so I clamped it on to get the holes marked up:
So got drilling!
After cleaning teh holes and giving them a squirt of zin primer, I added the rivnuts:
Screwed the grill on and added some bits to make sure it all looks ok:
So as I had the drill handy, I got drilling the holes for teh central locking and the door rubber:
Thats it for today
Q
#184 jamesquintin
jamesquintin
  • 1,025 posts
Posted 06 June 2018 - 06:24 PM
Not having a good day today. Focus failed its MOT, discovered I've been driving it around for 5 days without tax, and then get home to find the bikes have fallen off the garage wall and hit the car mid resto!
It's slightly dented the quarter panel. Luckily the door took most of the impact and thats waiting to be reskinned anyway.
Anyone got any tips for properly securing a bike frame to a wall..?
Q
#185 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 07 June 2018 - 08:07 AM
Nightmare. Bikes on walls are always a risk, and cause many a dented car but if you're pushed for space it's often the only way. There are lots of fancy wall brackets on the market, but before I had a bigger garage I relied on some cheap large self tapping rubberised hooks from B&Q. Drilled a tiny pilot hole in the wooden beam above the brick wall and screwed them in deep, then just hang the bikes vertically by front or rear wheel. If you do one by the front, then the next by the rear, you can do it with a small amount of space so the handlebars don't clash.
If you want to hang them horizontally by their crossbar then it's any decent hooks/brackets, but borrow a Hilti drill/gun or similar, to get some bolts deep into the brick. Standard plastic plugs and screws are a bit flimsy, depending on how many you're using and how heavy the bikes are.
Edited by rich_959, 07 June 2018 - 08:07 AM.
#186 jamesquintin
jamesquintin
  • 1,025 posts
Posted 17 June 2018 - 09:07 PM
Tiny bit done this weekend... the inner wing is a bit bent at the bottom from where I did some work on teh subframe ages ago (upper arm maybe?) I can't really remember what, but I did pull th ewing about doign whatever it was...
So I got my hammer and dolly out and went from this:
To this:
It's by no means perfect and I've never used a hammer and dolly before, but it should come up eventually!
The next job is to buy a jog to rotate the body on. I've been putting it off, but I really need to be able to spin it around to get the floor done. Problem is, I'm skint...
Q
#187 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 19 June 2018 - 05:33 AM
That sounds like one of the days I would have...
Its defo a good idea to do all your drilling before paint it makes all the difference...
#188 jamesquintin
jamesquintin
  • 1,025 posts
Posted 19 June 2018 - 02:44 PM
Decided to have a go at reskining the door...
Never done one before, but read plenty of post about doign it so jumped right in! Here's a look at what condition the door was in:
These were reskinned about 5 years ago, and they looked good from the outside, but on closer inspection, they are a bit of a bodge. You can see that the inner fold was never repaired and the new skin was folded straight over a rusty hole! Crazy. I'll obviously get the edges repaired properly.
Ground off the skin and was left with this:
Luckily the corners are fine, so gave everything a good cleaning:
ALso found the date stamp:
l1tp1Sp.jpg?1
Which makes my car a very late '97 MPI. Not sure when the MPI was officially introduced, but sure mines an early one!
Q
#189 minimissions
minimissions
  • 3,427 posts
Posted 20 June 2018 - 11:55 AM
I had the same with the dates on my Mini everything was 1995 as it should but the doors are like 4 months apart etc haha
#190 jamesquintin
jamesquintin
  • 1,025 posts
Posted 09 July 2018 - 06:16 PM
So, some more work on the door. Doing bodywork now is like wadeing through treacle. Anyway, got the old cut out and the new welded in:
The was a small crack just around the bottom hinge, so I welded that up and smoothed it down. It'll all need a skim of filler underneath, but nothing too major.
I got some of the bare metal seam mouldings from Minispares. They do fit, but when I first put them on I noticed they were just a little bent at the bottom...
A quick tap with the hammer soon sorted them out!
Q
#191 minimissions
minimissions
  • 3,427 posts
Posted 10 July 2018 - 05:37 AM
Nice tidy repair to that door I remember doing the same panel on the sidewalk..
#192 jamesquintin
jamesquintin
  • 1,025 posts
Posted 10 July 2018 - 05:02 PM
I'm determined to do a little every day from now on. I'm going to get the original sound proofing for the floor cut out as per the factory, so I've been working on the templates. Printed one out for the gear hole to make sure it fits:
vPm11Lq.jpg?1
Then I went over to a local platers with all the bits I need cleaning and re-zincing. I'll be getting back the shiny parts next week!
Q
#193 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 July 2018 - 06:29 PM
Very interested in the latest update James.
#194 jamesquintin
jamesquintin
  • 1,025 posts
Posted 11 July 2018 - 02:42 PM
more detailed bits. 90% of the time I'll get a panel on, and then not finisih the last 10%, which is why I keep flitting around the car. Anyway, i've fixed the bottom flange of the inner wing:
I also stuck a few spot welds on there for good measure!
Turning to the wing/scuttle area, I got it sanded down:
Looking better. Before I started the project, this was the bit I was most worried about getting wrong, but it was fine!
Although when you look closer...
These are the small flaws I'm worried I won't be able to get rid of...
Oh and because the wing is slightly nearer the car than the a panel is, I've had to take a small section off the back of the seam strip to get it to fit close to the body on the front side
Q
Edited by jamesquintin, 11 July 2018 - 02:45 PM.
#195 jamesquintin
jamesquintin
  • 1,025 posts
Posted 13 July 2018 - 12:38 PM
Urrrgh. Found the last bit of rust. I was hoping this was just surfce, but no, the top of the bulkhead is crumbling away, so I'm going to have to re-weld the top on:
This is the last of the bodges done by the guy who resorted the car last time. He didn't remove the flange from teh old dash rail, leaving 4 layers under the windscreen rubber! Also didn't use any zinc paint to protect the bare metal.
It'll look fine when its done
Q
5 user(s) are reading this topic
    Bing (3)
