Dvla Asking For Proof Of Mini So I Can Apply For Logbook Help?
Posted 24 January 2015 - 06:36 PM
Posted 24 January 2015 - 06:48 PM
They where all riveted on plates at that age. I don't think they started stamping the number into the scuttle panel until the 80s.
If you haven't got the plate it may be a case of trailering the car to a DVLA inspection centre so they can view the car in person. They would most likely check the body number on the car against the heritage certificate and issue the logbook.
Alternatively they may allow you to send them a scan of the certificate and a picture of the body mumber.
Posted 24 January 2015 - 08:41 PM
oh Christ Tom, I hope you sort it out ok
Ben
Posted 24 January 2015 - 11:40 PM
Regards
Jordan
Posted 25 January 2015 - 08:18 AM
Posted 25 January 2015 - 09:24 AM
Get a plate from Minimail, rivet it onto the top of the shroud. Take pics.
I assume that the DVLA want proof you actually have the physical vehicle as well as the paperwork.
See Minimail for details http://www.minimail....sis-vin-plates/
Posted 25 January 2015 - 01:11 PM
Sand down the cross member strengthening panel on the drivers side in the engine bay chassis number should be stamped there.
Regards
Jordan
Early cars did not have chassis numbers stamped into the body.
From 1979 VIN nos replaced chassis numbers and this was when the requirement to stamp the body with the VIN number started.
Minimail has all the detail info about chassis nos, commission nos and VIN nos
Posted 25 January 2015 - 06:15 PM
http://1959miniregis...ations-numbers/
Regards
Jordan
Ps hope this helps
Posted 26 January 2015 - 10:54 AM
Morris ones were embossed with the number (raised reverse stamped nos).
Not necessarily, saloons built at Cowley have characters stamped from above. Only Longbridge built saloons and all Morris Travellers, Coopers etc. which were built at Longbridge have the embossed characters.
The chassis plate should be screwed on not riveted.
