Bore Washing
Posted 23 January 2015 - 09:17 PM
Just two questions ,
When you hone a cylinder how much material are you removing?
What's the best way to clean a cylinder bore after a hone?
Posted 23 January 2015 - 10:35 PM
Posted 23 January 2015 - 11:17 PM
I'd measure any bore to see what it is compared to standard before honing, it may already be beyond spec and a rebore is required
Posted 24 January 2015 - 12:19 AM
That is the case more often than not.
Many have honed and fitted new rings, then a few thousand miles later the engine is smoking, using a lot of oil and suffering from 'blow-by'.
With that is involved in a complete strip down it really is not worth trying to cut corners.
Posted 24 January 2015 - 02:46 AM
As a minimum, from a fresh re-bore, 0.0025" need to be removed, however if only 'glaze busting' and existing bore, then it shouldn't be enough that could be measured with conventional Mics or Snap Gauges, provided of course that the Bores were satisfary to kick off with, ie, the orginal honing still completely visable. If that's gone, then it's a rebore as Cooperman has suggested.
<Edit: Washing of the bores afterwards can be done by forst a Hot Wash, then soap & water, then ATF on paper, finishing with plain 20 weight engine oil on paper, keep going with that until the wetted paper cames out as clean as it goes in.>
Edited by Moke Spider, 24 January 2015 - 02:48 AM.
Posted 24 January 2015 - 01:14 PM
