Posted 17 January 2015 - 09:59 PM
Posted 17 January 2015 - 10:05 PM
If it's trying to pump water through then it could be a blocked pipe, take off the pipe connected to the pump and try again (make sure you have something to catch the water in). if it comes out then it's likely to be a blocked pipe or jet.
Posted 17 January 2015 - 10:08 PM
If you can hear it trying then its ether the filter in the non return valve (if you have one) is chocked, or the jets are choked, so put a small needle in the holes and wiggle about as washer fluid does congeal, dont use air through the pipe it just blows the balls out.
Or something I come across from time to time the rubber impeller is stuck in the pump body and the motor shaft spinning inside the impeller,
Pull to outlet pipe off to see if any waters coming out the pump is so the jets are chocked.
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
