Hi peeps!
My 200 compressor broke down, just when I had do spray a car.
Whats the least tank size / 'pump rate' I'll need to spray a mini comfortably?
cheers!
Posted 17 January 2015 - 09:57 PM
Hi peeps!
cheers!
Posted 17 January 2015 - 10:08 PM
I think you need at least 50 litre capacity and 7cfm .
Posted 17 January 2015 - 10:22 PM
Darn the small one I have is a 35 litre tank, don't know howmuch HP it has to refill...
Posted 18 January 2015 - 12:10 AM
Posted 18 January 2015 - 02:08 PM
It really depends on your spraygun requirements, I use a devilbiss sri pro for most my work as it's fan is large enough for full panel spraying just a little slow compared to a gti pro, advantage is 2.8cfm requirement and less over spray, I however use a clarke se16c100 which can just supply enough air for both this gun and my airfed mask. But if I only needed to feed the gun could easily get away with a 2hp compressor with 50litre tank. A devilbiss gti however would need a 3hp at least to run.
My gun has a 1.5mm nozzle and max nozzle flow rate is 6.5 cfm.
Pressure should be around 4.5 bar.
Does this means it will need 3 litres of air / second , or will it need more like 15 litres / second?
Posted 18 January 2015 - 03:09 PM
