Head Gasket - Which Way Is Up?
Best Answer PaulColeman , 19 January 2015 - 10:40 AM
Okay, I rang the manufacturer this morning to get the definitive answer and it is as somebody previously said black composite side up. So I have it the wrong way round - bugger! The reason is that the black side is sticky and the metal side is not. The bores flex due to the compression and heat and the metal side of the gasket against the block allows the bores to move relative to the gasket without damaging it. With it upside down (as I have fitted it) it will fail between the bores where it is weakest. Oh well, you live and learn!!
Hopefully this will help somebody else in the future to not make the same mistake.
I have also suggested to this particular manufacturer that they include something to tell people which side is up.
Paul.
Go to the full post
16 replies to this topic
#16 Ethel
  • 25,919 posts
Posted 18 January 2015 - 01:30 AM
Too late I know, but you could have asked the supplier if you could look at others in their stock. One of the same construction for another engine that will only fit one way up should tell you.
#17 PaulColeman
PaulColeman
  • 712 posts
Posted 19 January 2015 - 10:40 AM   Best Answer
Paul.
Edited by PaulColeman, 19 January 2015 - 10:41 AM.
