Starter Motor Not Engaging (Inertia Type)
7 replies to this topic
#1 brownspeed
brownspeed
  • 451 posts
Posted 16 January 2015 - 05:33 PM
Back on the road for a couple of weeks now and trying to sort problems as they manifest themselves. My latest issue is an intermittent starting problem; the starter motor sometimes whizzes along merrily without actually engaging with the ring gear. I given a gentle tap on the starter casing it'll engage sometimes, other occasions it'll sort itself out; so I don't think I've a tooth/ teeth missing.
 I'll whizz it out over the weekend and check it out- my question is- should I just clean and degrease the shaft or is there a proprietary lubricant I should use? I think I used a dry graphite spray when I looked it over; this is clearly not helping!!
over to the audience..........
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 January 2015 - 06:34 PM
Dry Graphite is what I use, if thats not sorted it then it may be the bendix is worn causing the sticking, have you washed it off and seen if its showing signs of jamming.
#3 brownspeed
brownspeed
  • 451 posts
Posted 16 January 2015 - 08:36 PM
it got a good clean in December before we hit the road. will try again tomorrow.
if it turns out to be bolloxed, is fitting a pre-engaged type an option? I've heard there may be an issue with flywheel teeth being incompatible?
PS Thanks for the response
Edited by brownspeed, 16 January 2015 - 08:36 PM.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 January 2015 - 01:27 AM
You have to have the ring gear to go with the Pre-Engaged Starter I'm afraid
#5 brownspeed
brownspeed
  • 451 posts
Posted 17 January 2015 - 09:38 AM
suspected so :( thanks kernow.
#6 Ethel
  • 25,919 posts
Posted 17 January 2015 - 10:59 AM
An inertia should work well enough, but if you want to go pre engaged you could fit a high torque motor replacement for the inertia, pricier but not so much when compared to fitting a new ring gear as well.
Are you sure it's not a bad battery, any link between not turning over and being driven or weather?
#7 brownspeed
brownspeed
  • 451 posts
Posted 17 January 2015 - 02:37 PM
definitely sticking. its had a good clean and been showered in fresh graphite. hopefully that should be it. its heading towards a Basil Fawlty "this is your last chance, I've warned you about this" scenarios. if it does it again ill launch it.
by the way- how much axial float should be in the shaft?
#8 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 17 January 2015 - 08:36 PM
When I started working on cars (50 years ago) I was taught to wash the benbix In paraffin (petrol leaves a residue of the upper cylinder oils) dry it and leave it. No lubrication of any sort. It's always worked for me.
