Help please, again!
Reconditioned engine in my rebuild. Full of oil, filter primed, all connected up and ready to fire. Plugs out and turned many times ( to adjust the timing) but no oil pressure on the auxiliary gauge. The gauge works as grounding the wire to the sender raises the needle. Could be the sender I suppose but it's brand new and additionally, when you take the oil filler cap off and turn it over I'd expect to see oil gushing around, all looks pretty dry up there.
Only other change in the build is that I replaced the oil feeder pipe from the filter housing for a flexible stainless jobbie but I can't see that that would stop the pump priming. Any thoughts. I really don't wont to start a dry engine!
