2000 Cooper Sportspack Turbo
854 replies to this topic
#811 IronmanG
IronmanG
  • 1,225 posts
  • Local Club: Box hill. Lsmoc member
Posted 22 July 2023 - 06:57 PM
Which throttle body is that?
#812 Readers14
Readers14
  • 439 posts
Posted 22 July 2023 - 08:44 PM
Specialist Components maybe?
I’ve been eyeing these up myself  :proud:
#813 IronmanG
IronmanG
  • 1,225 posts
Posted 23 July 2023 - 06:36 AM
Not sure. Looked more like classic mini DIY 1
#814 Steve220
Steve220
  • 5,030 posts
  • Local Club: BMC
Posted 23 July 2023 - 09:00 AM
Its one of Coles DBW throttle bodies. Worked closely to help develop it, so might as well use one 😂
#815 IronmanG
IronmanG
  • 1,225 posts
Posted 23 July 2023 - 10:41 AM
Yep thought it was. Obvs direct competition to SC which is good to see. Not brought out the 50mm one yet?
#816 Steve220
Steve220
  • 5,030 posts
  • Local Club: BMC
Posted 23 July 2023 - 12:46 PM
No need. The inlet on this is 44mm tapering to 50mm. Velocity through it will be fine. Plus plenty of mid 200bhp a series minis on the HIF44 carbs 😎
#817 Steve220
Steve220
  • 5,030 posts
  • Local Club: BMC
Posted 07 August 2023 - 07:14 PM
Got the DBW working!
https://imgur.com/a/Mfw1JMg
https://imgur.com/a/jN75DFX
#818 Steve220
Steve220
  • 5,030 posts
  • Local Club: BMC
Posted 09 August 2023 - 12:46 PM
Wiring loom working and new custom LCD display for the DIN.
#819 Steve220
Steve220
  • 5,030 posts
  • Local Club: BMC
Posted 12 September 2023 - 07:33 PM
Finished up the wiring and tested, all good so far! ECU is reading all the sensors nicely. Engine came back out so I could have the bulkhead support welded in and heat proof matting installed. Whilst out, did a quick once over on the engine, came up with a new turbo oil drain idea, and re-thought the oil feed set up at the block. Anyway, you don't want a narrative.. heres pics.
#820 KTS
KTS
  • 2,416 posts
Posted 12 September 2023 - 07:55 PM
very neat and tidy. Nice work !
#821 fokko
fokko
  • 163 posts
  • Local Club: Mini Seven Club Nederland
Posted 13 September 2023 - 07:58 AM
Amazing work! I like the very neat wiring job you do! How do you label them? Is it heat shrink wrap with a piece of printed paper?
#822 Bobbins
Bobbins
  • 1,483 posts
Posted 13 September 2023 - 08:43 AM
Nice work, good use of the relay rail on the bulkhead :)
#823 Java_Green
Java_Green
  • 169 posts
Posted 13 September 2023 - 09:08 AM
Really nice work you are doing. It is fun to follow. I would most likely have had your ambition level it I could find the time.....
- What ECU do you use?
- What controls the centre display? (I guess you cannot feed it directly from the ECU)
#824 jamesquintin
jamesquintin
  • 1,017 posts
Posted 13 September 2023 - 09:49 AM
It won't be complete until there is an alternator sticker on it...  :lol:
#825 Steve220
Steve220
  • 5,030 posts
  • Local Club: BMC
Posted 13 September 2023 - 11:18 AM
Thank-you chap. Printable heat shrink.
