2000 Cooper Sportspack Turbo
854 replies to this topic
#736 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 04 June 2019 - 06:46 PM
Bit of an update.  Had a chat with SC - they weren't helpful.  Contacted SCS and got their updated cable for the ecu, much happier! Car booked in for the 18th for mapping :D
Went to Bingley with the forum, really good day and not too sunburnt after!
Finally got the SC subframe bolts installed, a comparison to old and new!
Ordered and installed some new DSN parts!
And a gratuitous photo at work!  I'm having this as a print made by the flying club :)
#737 Junior Mini
Junior Mini
  • 313 posts
Posted 04 June 2019 - 08:31 PM
That's been nicked for my new desktop picture  :proud:
Thanks Steve.
#738 GraemeC
GraemeC
  • 7,437 posts
Posted 04 June 2019 - 08:41 PM
How does those subframe bolts work if the shoulder is so much longer (or at least it looks to be)?
#739 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 04 June 2019 - 10:15 PM
The shoulder doesn't bottom out on the subframe. You can see how far the threads go in on the standard bolt by the lip of copper grease :)
Edited by Steve220, 04 June 2019 - 10:17 PM.
#740 GraemeC
GraemeC
  • 7,437 posts
Posted 05 June 2019 - 05:25 AM
The shoulder should bottom out - that’s what these bolts are designed to do. Gives just the right a,pint of compression on the bushes (same as with the rear trunnions pins and the front tie rods).
The copper slip doesn’t reach the end of the thread as the first part of the subframe has a clearance bore - the female thread starts further down the hole.
#741 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 05 June 2019 - 10:04 AM
Ah right, take it up with SC then. I'm solid mounted and they work fine for me.
#742 Chris.Williams
Chris.Williams
  • 679 posts
Posted 14 June 2019 - 09:23 PM
Hey Steve, to save me searching through your build, did you use a genuine Garrett gt1752 or an eBay equivalent?
And what has been your experience either way?
Chris
#743 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 14 June 2019 - 09:46 PM
Yeh, genuine garrett. I was lucky too as the one I bought had recently been re-cored! Spools very well!
#744 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 15 June 2019 - 05:01 PM
:highfive: The Ebay turbos must be made of cheese. £150 ish, and still making a profit? O_O
#745 burchy35
burchy35
  • 114 posts
Posted 15 June 2019 - 07:51 PM
I ran a Chinese 1752 for a couple of years with ok power (172) with no bother at all. I may of been lucky but it surprised me how it lasted taking the punishment of the track.
#746 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 16 June 2019 - 10:21 AM
They're not bad units, some of the quality is surprisingly good! I got mine for £90, but was stoked when I saw it had been reconditioned!
#747 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 04 July 2019 - 07:17 PM
A lot of you will know what happened to my car from either the other forum or instagram. Basically, the mapping session didn't conclude how I'd have liked, despite telling the mapper that it needs to be slightly richer than normal to compensate for the outer cylinders running leaner. It did make 150bhp & 146lbft of torque at 13psi on 95ron fuel though!
Aaaanyway. After a long morning of runs and refining, I noticed puffs of white smoke appearing from under the rear of the car after a pull. Spoke to Ben and he immediately shut off the engine. After stopping the fan and looking around for a bit, we couldn't see any leaks and checked all fluid levels. All good, so started it back up, white smoke billowed out the breathers (not good). A compression test revealed:
1 80psi
2 175psi
3 170psi
4 175psi
Not good. Ben said head gasket, I said piston, he said potential stuck valve, I said piston. We got into a debate of knock/fuelling and he said everything was where it should have been and was running rich top end. Anyway, I drove the car home with white smoke pouring out the engine bay everytime i had to stop, parked her in the garage and left her until the next day to pull the engine and found the following
Lean on the outers, anyone?
Cylinder 1 marks
Cylinder 3 grazing over the top of the gudgeon pin
Absolutely no signs of det/knock on the tops of the pistons (just lots of carbon), on the cylinder head or on the bores. Full strip down began.
Cylinder 1 exhaust valve
Pistons came out... and no surprises here!
Piston 1 with 2 broken ringlands on one side
Piston 3 with one broken ringland
Ringland piece removed
The outcome is slightly serendipitous. At the end of this year I was intending on building a V2.0 engine anyway, so this just gave me chance to do it now. I was on the phone to MED for most of the morning talking through piston options, sending them pics of pistons etc, and who they trusted to complete the build (they wouldn't do it as they only did race engines  :mmkay: ) I eventually went for Southam Mini & Metro Centre to do the engineering and bottom end build with the following spec:
Block bored to +0.040 - 1310cc
MED cast pistons with 10cc dish
Block to 11 stud
MED centre strap and ARP bolts
Matched A+ rods with ARP bolts
Polished crank
New ACL bearings all round
MED 1.3 roller rockers
They are also taking into account that it is a turbo engine, so the tolerances will be suited.
Whilst it was off, I also took the gearbox to John at Guessworks to investigate an issue with 2nd gear... and also as a late addition - a Quaife ATB diff from Swiftune :shades:
I also did a large gasket and seal purchase from Rimmer Bros
Got an insulating spacer for the inlet manifold (bored out to 50mm)
And the great guys at Forge Motorsport took pitty on me and I got a turbo blanket
Before it got comfortable in its new jacket, the turbo was stripped and is off to Telford Turbo's tomorrow morning for a bit of their magic!
So the conclusion to this. I'm not angry that the mapping wasn't right and the pistons let go, just frustrated. I did trust Ben to do a good job but I got every other reason of what it was rather than admit it was detination that killed off 2 pistons. I'm going back to Chris at EFi Parts for the next mapping session. My lessons from this - find a mapper that knows A series engines well, use super unleaded (98+ron) and do plenty of research before parting with your money; in ALL aspects of modification. The power I achieved during the mapping was almost exactly what I was after, I just need longevity now!
Hopefully I will get the engine and gearbox back at the end of next week.
#748 REVVIT
REVVIT
  • 341 posts
Posted 04 July 2019 - 07:47 PM
Sorry to here about your engine issue I've personally experienced rolling road dilemmas in the past with so called specialists..On a more important note i personally know the guys at southam you are in safe hands  :highfive:
#749 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 04 July 2019 - 08:05 PM
Shame about the problems you've had, especially an engine build so soon. As you say it's so frustrating.  What was wrong with your second gear? When are you hoping to have it back on the road? IMM?
#750 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 04 July 2019 - 08:10 PM
Second gear pops out occasionally on over run, John is looking into it. I'm hoping to have the car back together before the 18th as it is due to be at RIAT for the RAF Mini Club! As long as i can get the engine and gearbox a week tomorrow, i should be able to get it together and running! Cleaning won't take long as it's ceramic coated.
