2000 Cooper Sportspack Turbo
854 replies to this topic
#556 jamesquintin
jamesquintin
  • 1,017 posts
Posted 13 June 2018 - 07:27 AM
V nice. Your door gaps are also excellent.
One question about your grill, will the small screws that hold on the left/right surrounds scratch the paintwork..? When I added my rivets there doesn't seem to be enough clearance behind the grill for the screw to sit?
Q
#557 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 13 June 2018 - 08:36 AM
Q
Q - you know what, I've not even checked! It'll be something to investigate. Cheers mate
#558 mini_surfari
mini_surfari
  • 326 posts
Posted 13 June 2018 - 01:45 PM
looks brilliant, sat very well, although mine seemed to rub terribly that low....  >_<
#559 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 13 June 2018 - 02:59 PM
Thanks! It will have to go up as it won't get on a dyno being this low. Once it's all set up, it should be this low again if it doesn't rub.
#560 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 14 June 2018 - 03:03 PM
Looking good Steve! Can't wait to see it up and running. I love how it's retaining an almost OEM look, despite all the special bits!
In your research, did you come across any full kits for fitting a Turbo to an MPI? I've seen the same sort of thing for Superchargers (Vmaxscart) but never seen an MPI specific 'off the shelf' kit for Turbocharging.
Thanks chap! There is literally nothing out there for these blocks.
Sounds like you need to go into business with your own conversion! ;D
#561 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 14 June 2018 - 03:46 PM
Lol if it weren't for the limited production run and my spare time being used up, don't think it's worth it! I'm pretty sure anyone looking at my thread could do the same thing though.
#562 1330RG
1330RG
  • Just Joined
  • 219 posts
Posted 15 June 2018 - 07:34 PM
Excellent level of finish!
#563 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 19 June 2018 - 09:44 PM
Q
Q,
So had a look, and the screw ends that hold the hockey sticks in are so short they don't get anywhere near the paintwork! Gave it a mock up and now I can't stop looking at it!
Also fit the turbo, the oil return took an hour to tighten up as I could only do a bit at a time because of the room :( and my arm ached!
#564 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 20 June 2018 - 09:35 AM
Love the quality of this build
.... though i'm still a little worried about some of the earlier pics showing turbo bits made out of cardboard, not sure they're going top be up to the job :P
Steve: have you got a back-up vent set-up for the oil catch tank?  As we both know MPIs are not supposed to vent oil fumes to air, so if you get a really scrupulous MOT tester!
Edited by Itsaminithing, 20 June 2018 - 05:46 PM.
#565 Bat
Bat
  • 903 posts
Posted 20 June 2018 - 09:44 AM
Hi,
I could see no mention of testing breathers in the mot testers manual?
Cheers  :proud:
#566 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 20 June 2018 - 10:47 AM
Steve: have you got a back-up vent set-up for the oil catch tank? As we both know MPIs are not allowed to vent oil fumes to air, so if you get a really scrupulous MOT tester!
My pipes are being done by Fusion Fabrications, Matt wouldn't let me use card... spoil sport.
My catch can is hidden in the inner wing, you can't see if it vents to atmosphere or not. If they get pissy, then it's not hard to feed it into the inlet.
#567 Itsaminithing
Itsaminithing
  • 852 posts
Posted 20 June 2018 - 06:31 PM
Hi,
Cheers  :proud:
Emission systems don't seem to be mentioned for petrol cars in the manual.
Some testers can get a little fractious when faced with a modified system venting to the atmosphere & start talking about emission of air quality pollutants (regulated by Euro emissions standards etc etc).... & lets face it who wants to upset a MOT tester at such a critical time.
NB; A fluid leak that creates a pool on the floor within 5 minutes that's more than 75mm in diameter constitutes a failure -luckily that only applies to the vehicle & not the owner!
#568 Bat
Bat
  • 903 posts
Posted 21 June 2018 - 08:13 AM
Hi,
First thing to do is refer them to the manual, that's what it's for.
The manual is to make sure your vehicle is fairly tested, not what the tester thinks is correct but what is correct.
Imagine you took a 1970 mini for test and it failed for no fog light. Would you fit lamp, switch and wiring or turn round to the tester and say they don't need one at this age?
Cheers  :proud:
#569 Haygate
Haygate
  • 115 posts
Posted 23 June 2018 - 06:37 AM
Wow that looks absolutely stunning, how much ?
#570 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 23 June 2018 - 09:02 AM
Thanks! And even seriously I don't think I could sell this car
