Thanks!
The love/hate relationship with this car continues. As mentioned previously, i managed to get the carpet sorted! Its now all glued in and sitting quite nice. I bought some fabric spray dye too as felt some areas were a bit 'grey' rather than black. Will get pictures of that some other time.
Got the O rings for the indicators - for some reason mine didn't have any!
3rd brake light wired into the N/S rear brake light and earthed at the point underneath.
FINALLY got my brake pads too, been trying to get a hold of a set of Ferodo pads for months and these eventually came up at a good price. Chopped off the sensor wires
Rear lights going on! I REALLY don't like the way the 'new' seals fit against the light housing and the body. May have to re-think that as i feel it may let water in still.
Filled the clutch master cylinder and managed to bleed it by myself (which i was amazed at!). Operates nicely throughout its 6.5mm throw! However, i moved onto checking all the brake lines, making sure all were tight and secure. Filled the master cylinder and went for some lunch. On returning I found the right hand union on the proportion valve was leaking all over the engine bay and a pool of fluid was over the floor. Out came the soapy water to get rid of it all! Once dry i took this pic, you can just see the weeping. I drained the fluid and removed the hose, using one of my mum's old nail files, i flattened all the paint etc on the face and refitted. Seems to have done the trick!
After some sorting out in the garage i found more parts I could fit to the engine whilst at this point, so alternator was slapped on, belt fitted and tensioned and mock fitted the turbo and inlet!
I stuck it in 4th and got the engine turning over so i could set the valve gaps; 0.32mm all round (12 thou). Then stuck the rocker cover on.... because i could! I love this next photo. Its currently my desktop background on my laptop lol
More to come tomorrow!
Edited by Steve220, 26 April 2018 - 09:14 PM.
