2000 Cooper Sportspack Turbo
854 replies to this topic
#241 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 02 August 2017 - 08:43 AM
Bit late now but when i drill hinges, I take a grinding stone to the weld on the other side and grind it flush with the hinge body before drilling.
Makes it easier
Ben
Hi Ben, that's what I did, still a pain!
#242 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 09 August 2017 - 08:33 PM
Floor and door surrounds in!
#243 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 August 2017 - 06:51 PM
Coming along!
#244 Haygate
Haygate
  • 115 posts
Posted 13 August 2017 - 07:48 AM
Looking good.
#245 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 15 August 2017 - 01:50 PM
Thanks guys!
Well one of my final order of parts from minispares made last night. Hopefully that'll be with me this week. So moving on, I got the engine back from Rob walker and immediately got onto stripping the rust off and painting.
Put 2 very thick coats on and it'll have another before I fully reassemble it.
Next was onto piston rings. These were done in the standard method - Rings individually put into each bore and straightened using the piston. I got the following results
From the research i've done, these all sit well within tolerance straight out the box so i'm extremely happy I don't have to file them! With that, all rings were fitted to pistons.
Onto a controversial topic - I've reset my speedo to account for the almost total rebuild of the car and engine. I took a photo of the mileage before hand and then reset it to zero. To make sure it's working, I attached the speedo drive to a drill and put on a few miles to see if it was all serviceable.
I need the new bearings and ring compressor before I continue with the engine. Hopefully i'll get all of that this week so it'll give me something to do!
#246 jamesquintin
jamesquintin
  • 1,017 posts
Posted 16 August 2017 - 07:49 AM
NIce. What work did you get Rob Walker to do to the block? I need to have mine looked at as well and have been quoted £2.5K to do the whole engine/gearbox, which I just can't afford
I'd be wary of changing the speedo millage, will cause problems at MOT time and if you want to sell it...
#247 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 16 August 2017 - 09:07 AM
The speedo is more controversial than it is a problem. I've done this to a few rebuilds in the past. The only illegal part is to sell the car falsifying its mileage.
Rob re-bored to 1293, installed cam bearings, reground the crank, balanced the entire bottom end and fully degunked/cleaned the block.
#248 timmy850
timmy850
  • 3,319 posts
  • Local Club: MITG
Posted 17 August 2017 - 09:59 AM
Don't think of it as winding the miles back to zero, think of it as increasing to 100,000!
#249 gadget555
gadget555
  • 152 posts
Posted 18 August 2017 - 09:40 PM
Just spent the last 2 nights (at work) reading through your whole tread, keep up the good work and I look forward to your updates.
#250 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 19 August 2017 - 02:34 PM
Thanks! There's a few more coming. Had my first dealing with deox C and it's amazing!
#251 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 20 August 2017 - 01:56 PM
Updates continue as parts slowly come my way.
Bearings turned up from MED and got them fitted and plastigauged, all well within tolerance!
Whilst the block was upside down, I fitted my new light weight followers.
Also had my bilt hamber turn up, Deox C and electrox, so got started on that!
After 12 hours I brushed the rust off and resoaked over night. Did it until all rust was gone then sprayed 2 thick layers of electrox on all parts.
Also had to repair one of my trailing arms as rust was starting to come through the paint.
Awaiting a minispares delivery so I can finish the engine and get it built up! Also looking into replacing my cam with something a little more suited for a turbo application. Got a lot of recommendation for the Kent 274, but also keeping my eye out for an MG cam!
#252 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 20 September 2017 - 06:32 PM
Time for an update
Shiny DSN stuff
Installed crank, found out the tolerance for end float was tiny! Need to linish the thrust bearings.
Oil pump and piston installation
Although I cracked a ring getting it in because the ring compressor I have is crap.
Primary gear in and tolerance is bang on still (not sure why I was so surprised)
Rockers needs a good clean up, so stripped, cleaned each part, oiled and rebuilt again
Rear subframe built up for Jez to do alignment on the boot floor and brackets
And after a visit to the man himself, a few pics of the bodywork!
He admitted himself the clean up of the welds isn't complete and there's a few touch up areas he wants to re-attack, so letting him just crack on with it! Going over tomorrow to take more pics as apparently the inner wings and front panel is on! He's also been given the doors as I want them painting inside before assembly. I've overloaded him with work! But he's definitely the man in the know!
Next on the list is getting the camshaft in the engine, linish the thrusts to get the right end float and get ready for the cylinder head and gearbox! All the brackets etc that have been in electrox are now painted satin black.
#253 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 20 September 2017 - 08:19 PM
Nice progress  =]
#254 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 28 September 2017 - 11:57 AM
Dropped the rear subframe off with Jez and had a nice surprise of the front end being on!
He said there's a fair bit of wiggle work to do to make it perfect and for the bonnet to fit against the wings, but i'm sure he'll get there! Only the doors and rear valances to do i think!
#255 Haygate
Haygate
  • 115 posts
Posted 29 September 2017 - 05:53 AM
Looking good, can I ask whos doing the work on the panels etc? Save reading back through the thread. Cheers
