Hi all,
Does anyone know where I might be able to purchase both the upper AND lower dash pads with vinyl covering already attached? I've checked all the major sites and unfortunately I can't seem to track them down. I'm looking for a set in black vinyl.
Cheers,
GK
Upper And Lower Dash Pads
Posted 14 January 2015 - 08:24 PM
Posted 14 January 2015 - 08:49 PM
They are pretty easy to re-cover yourself, you'd be surprised. I re-covered mine, took about a day to do both top and bottom, as dying time is where the time is at. Did them around two years ago and they not showing any signs of peeling away or anything.
<- had to re-do the bottom one where my switch panel had a sharp edge and damaged the vinyl.
Yams
Posted 15 January 2015 - 02:58 AM
Thanks Yams, but the problem is my Mini didn't come with the upper rail and I destroyed the lower one in the process of stripping for paint.
/sigh
Edited by gkmini, 15 January 2015 - 02:59 AM.
Posted 15 January 2015 - 07:15 PM
Posted 16 January 2015 - 02:48 AM
Posted 16 January 2015 - 06:53 AM
it should do as i dont think they ever changed the design of the dash rails from when they where first introduced
Posted 16 January 2015 - 11:10 AM
as Andy said, should fit fine. You can then just re-cover it whatever colour you like. I applied some strong adhesive, stretched the vinyl around the dash and kept it in place with clips all along the edges while it dried, i took care not to stretch it too much so it wouldn't shrink back and break the bond. it's far cheaper and looks more stock than the dash covers you can buy already made.
Posted 19 January 2015 - 01:08 AM
Posted 20 February 2015 - 10:28 PM
You can just paint the top and bottom dash rails.
Theres an article on a Polish MK1 in Marchs edition of Mini Magazine with painted dash rails.
Does look mint.
