Hey guys, I have decided to install an aftermarket Tach to my mini to help with learning to drive, and I have all the correct wiring diagrams except I cannot find which colour wire in the wiring loom I would attach the dimmer to. The Tachometer has an orange cable for the dimmer and the car model is a 1990 Rover Mini city 998. Thanks for the help guys.
2 replies to this topic
Posted 14 January 2015 - 05:00 PM
Posted 14 January 2015 - 10:05 PM
Red with green is usually the dash illumination wire colour so tapping into this on one of the existing clocks should be what you need.
Posted 14 January 2015 - 10:07 PM
Don't confuse with green with red wire. That's left indicator light.
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
