Boot Carpet Liner
11 replies to this topic
#1 MINI.G
MINI.G
  • 36 posts
Posted 13 January 2015 - 09:00 PM
Hi, was looking into buyer a boot carpet liner for my mini to tidy up the boot, but had a few questions first. I have seen some threads previously but couldn't find the detail I was after.
How do they fit into the boot exactly?
It sounds like the panels just sit there?
Are they actually worth the money?
Thanks! These are the ones I was thinking of getting:
http://optauto.easys...ningKitOriginal
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 13 January 2015 - 09:55 PM
Yep they just sit there, I got rid of mine as it made the boot even smaller, I just cut out a bit of plastic (can use plywood) the same shape as the floor above the spare wheel so the boot is all flat.
#3 Chris1992
Chris1992
  • 2,022 posts
Posted 13 January 2015 - 10:18 PM
ive got a similar one which also just sat there, but i improvised with some brackets/wood/screws/glue/swearing and now it does the job perfectly  :proud:
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 13 January 2015 - 10:44 PM
They do neaten things up a bit, but then they also reduce your already small boot space quite a bit too. If you don't really use your boot all that much, or you more tend to use your rear seat as a make-shift boot, then that's not going to be so much of an issue. If however your mini's a weekend show goer & you therefore need every available inch of space to cram with tools, spares and camping gear etc, then they can be a bit of a pain.
#5 1984mini25
1984mini25
  • 8,784 posts
Posted 13 January 2015 - 10:49 PM
I've just got a sheet of mdf cut to size and covered for mine. One day I'll eventually get round to making up some proper brackets for it, but has been fine so far.
#6 Minimad100
Minimad100
  • 416 posts
Posted 13 January 2015 - 11:12 PM
Here's a before and after of mine, another thing I would add is my car being an MPI has the washer bottle in the boot, the boot board makes filling this up very annoying....
Edited by Minimad100, 13 January 2015 - 11:37 PM.
#7 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 13 January 2015 - 11:34 PM
Here's a before and after of mine, another thing I would add is my car being and MOU has the washer bottle in the boot, the boot board makes filling this up very annoying....
i made my own with a hole for access to the washer bottle and a hatch to the battery. In the pictures I had lots of brackets pinning it together, these have now been removed, and the boards stay in place no problem.
03600719-F735-49FF-A907-AC47931091C0-483
#8 Minimad100
Minimad100
  • 416 posts
Posted 13 January 2015 - 11:39 PM
i made my own with a hole for access to the washer bottle and a hatch to the battery. In the pictures I had lots of brackets pinning it together, these have now been removed, and the boards stay in place no problem.  03600719-F735-49FF-A907-AC47931091C0-483
Nice! I need a clamp the left hand side around the petrol tank also! One of the many jobs!!!
#9 splintercat
splintercat
  • 616 posts
Posted 14 January 2015 - 05:57 PM
This is mine...............a bit rough I admit but I like it. Especially as these bags aren't too readily available.Attached File  20140605_154121.jpg   62.76K   19 downloads
#10 roberts
roberts
    Optimise Automotive
  • 3,295 posts
Posted 15 January 2015 - 01:08 PM
Good afternoon,
A fitting guide can be found on the website here: LINK
Yes, they simply slide into place with a tight fit, the base baord has a support on the right and along the front, and then the left hand side and back sit on the spare wheel - the other boards than fit in and around it.
I have to disagree (sorry haha), the reason why I originally developed the boot liner for my Mini (way back in 2003 and way before Optimise was even a consideration) was because I used my boot regularly and was fed up with everything falling in and around the spare wheel, getting creased (it was often my college work that I kept in the boot) and/or dirty.
The boot liner creates a clean and level environment to put stuff on, yes it's a little smaller - but I think it actually makes the Classic Mini boot more usable, especially if you use the boot on a day to day basis.
Andy @ Optimise Automotive
#11 roberts
roberts
    Optimise Automotive
  • 3,295 posts
Posted 15 January 2015 - 01:12 PM
That looks like one of our kits?
If so, you only need to remove the right hand side panel to gain access to the washer bottle. As the right hand side board sits on top of the base board - so it's not really much to do, removing and then installing the right hand side board only takes a min tops.
As above, the kit was originally developed back in 2003 for my Mini and I had an SPi, so the washer bottle was in the boot - which is why it was designed to have easy access to the washer bottle.
#12 Minimad100
Minimad100
  • 416 posts
Posted 15 January 2015 - 01:31 PM
Here's a before and after of mine, another thing I would add is my car being an MPI has the washer bottle in the boot, the boot board makes filling this up very annoying....image_zps601c16d9.jpgimage_zpsfcbd68d1.jpg
Indeed it is one of your kits! Like you say the right hand side is reasonably easy to remove! I'm thinking of just putting a small handle or knob (now now children...) just so removing the panel is even easier!
Other than that nothing but praise from me! Tidy's the boot up nicely!!
