Converting From Mechanical To Electric Fuel Pump
24 replies to this topic
#16 limby2000
limby2000
  • 366 posts
Posted 17 January 2015 - 08:15 PM
Hi almarsh, ive got a facet pump with pre-filter and also a malpasi filter king regulator, the one with the glass bowl and filter. They are used but I've now gone down the s/c fuel injection route so now gathering dust. If your interested you can have them for 25 plus postage. If your nred a pic let me know.
#17 almarsh132
almarsh132
  • 390 posts
  • Local Club: Medway Mini's
Posted 18 January 2015 - 11:26 AM
Yeah i am definitely interested, would be able to put a picture up?
#18 limby2000
limby2000
  • 366 posts
Posted 18 January 2015 - 02:05 PM
Right, just to let you know tried pump with power, it intermittantent works (pumping noise) however unable to try with petrol. The pumps can be stripped and fettled with however you can have it with the filter regulator free, for 20 pound posted.send me your email and will send pic.
#19 Jordan18
Jordan18
  • 47 posts
Posted 29 October 2016 - 05:44 PM
I'm looking to do this in a week or two, can anyone tell me if I need a return line? And has anyone used braided lines if so can you use fitting such as these:http://www.viperperf...separators.html
This isn't the first time I've ever thought about this, and I'm unaware what point I should start at and what fittings I will need to have an electric
Fuel pump and braided lines with the fittings.
Cheers,
Jordan
#20 dodge44
dodge44
  • 53 posts
Posted 29 October 2016 - 08:45 PM
Added safety of not having the car stolen, more relibility in corners and an easier to replace pump of it goes.
You do risk fuel pumping on a burning car in case of accident, unless you fit à inertia switch
To put another side to that - I went the other way many years ago and have had the same AUF 705 mechanical fuel pump for the last 150,000 faultless miles - and it was 2nd hand when I got it. This replaced a troublesome original AUF 200 electric pump. I appreciate this was lashed to the subframe, not stowed in the boot or mounted on the bulkhead so was more vulnerable than what is being considered here but all the same the original mechanical pumps were good.
#21 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 29 October 2016 - 08:52 PM
My new car has an electric pump, the mechanical pump is still on the engine. It this right, or does it need the blanking plate fitting? Also, where would the inertia valve be, so I can check one was fitted?
#22 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 30 October 2016 - 10:15 AM
My mechanical pump was so noisy, I replaced it this week:
You get that nice, comforting thunka-thunka the SU pumps made when you first switch the ignition on :-)
#23 finch661
finch661
  • 2,339 posts
Posted 31 October 2016 - 07:35 AM
what punp is that?
#24 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 31 October 2016 - 11:03 AM
what punp is that?
It's an ECCO LM102 Mr Finch
#25 finch661
finch661
  • 2,339 posts
Posted 31 October 2016 - 01:06 PM
what punp is that?
cheers buddy :)
