Converting From Mechanical To Electric Fuel Pump
24 replies to this topic
#1 almarsh132
almarsh132
  • 390 posts
  • Local Club: Medway Mini's
Posted 13 January 2015 - 12:30 PM
What exactly is require. Power will be below 100hp so will not need a super duper race spec system, just something for fast road. Any advice? Pictures welcome!
#2 robminibcy
robminibcy
  • 1,516 posts
Posted 13 January 2015 - 12:40 PM
pump with inlet filter and out let union, facet road pumps are well reviewed and ive not had any isseus with mine,http://www.minispare...ch/classic/fuel
pump mounting.http://www.minispare...sic/FPA905.aspx
wiring (just an ignition feed and earth).
mechanical fuel pump blanking plate. minispares sell these or you can make one http://www.minispare...ch/classic/fuel
new gasket for fuel pump blanking plate http://www.minispare...PA905.aspx|Back to
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 13 January 2015 - 12:43 PM
Well a new pipe to bypass the mechanical fuel pipe, a new piece of hoseto go from the electric pump to the pipe at the back of the car, i usually install the pumps in the boot.
also wiring from an ignition live to the pump... Then an earth
HTH
#4 nicklouse
  • 18,576 posts
Posted 13 January 2015 - 12:46 PM
I would also use a suitable pressure regulator for the type of Carb you will be using.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 January 2015 - 12:55 PM
An an inertia switch would be a good idea.
#6 almarsh132
almarsh132
  • 390 posts
Posted 13 January 2015 - 01:35 PM
Wow that was quick, thanks all!
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 January 2015 - 01:51 PM
You can buy a Facet pump with a 2.5psi output pressure and you wont need a regulator
#8 nicklouse
  • 18,576 posts
Posted 13 January 2015 - 01:55 PM
I would always pump from the tank at a higher pressure than needed and regulate close to the carb. reduces any fueling issues. which can appear when the engine has a bit more power and better grip.
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 January 2015 - 03:56 PM
The 2.5psi Facet pump can provide 20gallons a hour which is far more then a road going A Series will need, it just cuts down on having another component inline and that volume of flow in my opinion is well up to the job and has no issue on my 95 bhp which I hope won't ever develop a thirst beyond that :lol:
#10 almarsh132
almarsh132
  • 390 posts
Posted 13 January 2015 - 04:50 PM
Have you got any pictures of yours mounted?
#11 robminibcy
robminibcy
  • 1,516 posts
Posted 15 January 2015 - 12:49 PM
I can get one at the weekend for you. I used a spare metal bracket i had lying around and bolted one end to the the flat bit of the rear subby then mounted the pump on the bit of metal using the rubber bushes. Cut the fuel line and attached one end to the inlet with the filter then the other to the outlet. When I brought the car it had a pump in the boot, not sure what sort it was but it ended up getting knocked around by stuff in the boot and eventually emptied about quater of a tank on to the boot floor! Something to bear in mind if you mount it inside the car.
#12 olly33
olly33
  • 758 posts
  • Local Club: 42nd Street (back in day)
Posted 15 January 2015 - 07:41 PM
Sorry to hijack this thread,but what is the benefit of fitting a electric pump over the standard mechanical one from factory?
#13 Dusky
Dusky
  • 5,322 posts
Posted 15 January 2015 - 08:07 PM
Added safety of not having the car stolen, more relibility in corners and an easier to replace pump of it goes.
You do risk fuel pumping on a burning car in case of accident, unless you fit à inertia switch
#14 IainNeon91
IainNeon91
  • 1,287 posts
Posted 15 January 2015 - 11:19 PM
I came across this installation/wiring guide whilst considering the conversion myself...
http://www.dummett.n...mp_fitting.html
#15 almarsh132
almarsh132
  • 390 posts
Posted 16 January 2015 - 08:14 AM
Inertia switch sounds like a no brainer to me then!
