Brake Bleeding Sequence
Best Answer A-Cell , 12 January 2015 - 12:17 PM
For RHD version of your car, Haynes is the correct sequence. Same as Rover Workshop manual.
Front first because of the biggest displacement, longest line at front (LH), then RH front. Followed by longest line to rear (LH) Go to the full post
10 replies to this topic
#1 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 11 January 2015 - 09:32 PM
Hi guys,
I've bled the brakes on my 1992 (servo) Mini and the brakes are a little spongy.
In the past I've always bled the brakes NSR, OSR, NSF, OSF (furthest bleeding point away moving around to the nearest bleeding point) but after looking in my Haynes manual it says it should be NSF, OSF, NSR, OSR for my type 4 tandem master cylinder (servo).
Does anyone know which one is right before I waste my brake fluid?
Cheers,
Ian
#2 087dave
087dave
  • 952 posts
Posted 11 January 2015 - 09:49 PM
I always do (from standing behind the car facing forward) left rear, right rear, front passenger , drivers side..
Do you have the calipers on the correct way round?
#3 59 Speed
59 Speed
  • 674 posts
Posted 11 January 2015 - 10:00 PM
Cheers, yes the calipers are the right way up.
My brother says it's probably a bit of air still in the system and questioned the braking sequence, so I double checked against the Haynes manual and it says NSF, OSF, NSR, OSR which is complete different from the way I'm used to (your way).
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 11 January 2015 - 10:11 PM
Do it your way, silly question time.... Are the rears adjusted correctly??
#5 One step at a time
One step at a time
  • 282 posts
Posted 11 January 2015 - 10:21 PM
[quote name="087dave" post="3201527" timestamp="1421012950"]
 This is the way I've always bleed mine. The NSR is the longest pipe in the system, then OSR, NSF and lastly OSF.
Are you pumping the peddle or useing an easy bleed pressured type?
#6 59 Speed
59 Speed
  • 674 posts
Posted 11 January 2015 - 10:47 PM
Not adjusted as of yet :-|
That's what I always thought - longest pipe first and so on until you get to the shortest / nearest.
Easy bleed.
Cheers,
Ian
#7 spiguy
spiguy
  • 1,537 posts
Posted 11 January 2015 - 11:15 PM
Fair point Cal, you need to adjust the rears properly before assessing the brakes for sponginess. If the rears need to come out too far then that can create the same impression. I used to on occasion need to crack open the pipe unions at the master cylinder and bleed them (same approach - pressure on pedal, crack pipe until fluid coming out free of air, close pipe). Just thought I'd mention it.Seemed like an air bubble could get trapped in the body of the master cylinder.
#8 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 12 January 2015 - 11:01 AM
Yeah also check the PDWA valve on the bulkhead too, air can get trapped here too
#9 A-Cell
A-Cell
  • 1,610 posts
Posted 12 January 2015 - 12:17 PM   Best Answer
#10 59 Speed
59 Speed
  • 674 posts
Posted 13 January 2015 - 05:52 PM
Thanks guys,
Did it like A-Cell and the Haynes manual explains above, pedal much more solid and consistent!
Cheers,
Ian
Edited by Smackfiend, 13 January 2015 - 10:28 PM.
#11 A-Cell
A-Cell
  • 1,610 posts
Posted 13 January 2015 - 06:33 PM
Glad you got it sorted.
