Front Subframe Mounting
van
4 replies to this topic
#1 bertyfish2
bertyfish2
    Just On Tickover
  • 6 posts
  • Local Club: kent
Posted 11 January 2015 - 07:14 PM
Hi,
I am rebuilding a 196 van, the front subframe seems to be shaped to bolt direct on to the two holes in floor pan, I have brought new front rubber mounts but these do not line up to be used.
Any body know was this model a direct bolt on subframe ???.
#2 nicklouse
  • 18,400 posts
Posted 11 January 2015 - 07:18 PM
1960 is full solid mount.
#3 Tupers
Tupers
  • 4,134 posts
Posted 11 January 2015 - 07:52 PM
As above the front subframe bolts directly to the body shell on your age van.
Rubber mounts were not introduced for the front subframe until 1976.
#4 bertyfish2
bertyfish2
    Just On Tickover
  • 6 posts
  • Local Club: kent
Posted 14 January 2015 - 10:02 AM
Hi All,
Thanks for the responce, next to sell the complete new set of rubber mounts supplied by Mini centre, As I intend to fit a 1275 engine any advice on the gear box / linkage hole and fitting. ??.
thanks.
#5 nicklouse
  • 18,400 posts
Posted 14 January 2015 - 10:07 AM
Hi All,
thanks.
err fit it. there is no difference.
or are you looking to change the gearbox style and type?
Also tagged with one or more of these keywords: van
