How To Remove A Door
14 replies to this topic
#1 hitchinbloke
hitchinbloke
  • 49 posts
Posted 10 January 2015 - 01:46 PM
I have a old rotton door, and I now have a shiny new one. How do I remove the old one to replace it. I can't get near any of the screw hole....
#2 petey81
petey81
  • 1,322 posts
Posted 10 January 2015 - 01:47 PM
Go under wing/flitch panel. You may need to soak the bolts to loosen them up.
#3 hitchinbloke
hitchinbloke
  • 49 posts
Posted 10 January 2015 - 01:49 PM
Ouch. That will not be easy haha Bugger
#4 petey81
petey81
  • 1,322 posts
Posted 10 January 2015 - 01:54 PM
I bought these very easy.
#5 hitchinbloke
hitchinbloke
  • 49 posts
Posted 10 January 2015 - 01:59 PM
Cool thanks
#6 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 10 January 2015 - 02:00 PM
undo the bolts, snap every single one, swear, cry, hope the new doors have good threads and nuts... refit, done
#7 hitchinbloke
hitchinbloke
  • 49 posts
Posted 10 January 2015 - 02:26 PM
Haha the New door has good nuts and threads haha
#8 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 10 January 2015 - 03:00 PM
Give the nut/bolts a wire brush, as above soak them in penetrating oil, then loosen them a tad and tighten them back up to free the rusty bond, you'll probably have to do this a few times. they are 7/16" by the way
#9 Stu.
Stu.
  • 912 posts
Posted 10 January 2015 - 04:24 PM
It's sometimes best to try and tighten the nut before trying to undo it. It sometimes works, sometimes not. It's best not to lose patience. Take your time and use plenty of release spray before and during removal.
#10 hitchinbloke
hitchinbloke
  • 49 posts
Posted 10 January 2015 - 04:43 PM
Cheers Guys. I have done minis befo're, I seem to have dropped a massive one when buying this one, keeps getting worse
#11 hitchinbloke
hitchinbloke
  • 49 posts
Posted 15 January 2015 - 12:54 PM
Right. Have all off part from the top one which seems to be proper buggered. Nothing will grip it. Can I drill the bolt off?
#12 petey81
petey81
  • 1,322 posts
Posted 15 January 2015 - 01:12 PM
I bet you the tools i mentioned will.
#13 rodandtom
rodandtom
  • 998 posts
Posted 15 January 2015 - 02:05 PM
You can buy sockets that are specifically designed to grip rounded bolts. I'm not sure what the brand is. As long as you have soaked and soaked the nut to penetrate the rust they may help you.
Rod
#14 petey81
petey81
  • 1,322 posts
Posted 15 January 2015 - 03:21 PM
I put a link up.
#15 alex-95
alex-95
  • 6,025 posts
Posted 15 January 2015 - 08:10 PM
You can tap a slightly smaller socket on it, then undo it.
