One Millionth Hydrolastic Unit - Gold Plated
13 replies to this topic
#1 mab01uk
mab01uk
  • 12,413 posts
Posted 10 January 2015 - 10:36 AM
The one millionth Hydrolastic unit was gold plated and presented to Dr Moulton who invented the system.
http://www.hydragas.co.uk/history.html
Hydrolastic (wet) suspension was first used on the ADO16 BMC 1100 range in 1962, as it was not ready in time for the launch of the Mini in 1959 but was later fitted to the Mini from 1964 to 1971 until cost cutting under BL saw the Mini return to rubber cones (dry) suspension.
Edited by mab01uk, 10 January 2015 - 03:22 PM.
#2 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 10 January 2015 - 05:26 PM
Thanks for sharing these videos. The second one on the dirt stages looks like that episode of top gear when they compared how two cars performed recording the horse racing.
#3 mab01uk
mab01uk
  • 12,413 posts
Posted 28 June 2015 - 09:50 PM
Interesting cross section through an old Hydrolastic Displacer by Minimail (Refurbished and re-hosed units are available from Minimail - £132 inc VAT on an exchange basis).
http://www.minimail.co.uk/parts/
Edited by mab01uk, 03 May 2022 - 05:43 PM.
#4 mab01uk
mab01uk
  • 12,413 posts
Posted 10 January 2016 - 07:57 PM
Found this interesting write up below on the 'Landcrab' forum, originally published in the ADO16 club magazine and thought it worth posting here:-
The future of Hydrolastic suspension
All owners of Hydrolastic-sprung cars certainly know the big advantages these suspensions give to the ride and handling of the cars. But many will by now also know the downside. Due to the age of the systems, failures of spring units start to get more often. Bear in mind, that nearly all Hydrolastic units are now older then 40 years! Quite impressive for a highly loaded piece of rubber, which forms the spring in these cars.
Keep it or replace it?
It cannot be denied that modern standard steel spring and damper suspension have come a long way since the 60s and do work very well. And computations can help to adjust the rates close to getting perfect even before the first test drive. With this in mind, the question should be allowed, if a replacement made of standard springs and dampers cannot be made. Of course this is possible and has already been done to my knowledge to at least one 1300 and one Austin Allegro. And there are – of course – kits available to replace the rubber springs in Minis and Hydragas on the MGF. But this requires quite a bit of effort and specifically made parts, so it will be quite expensive.
So why not try to keep Hydrolastic? There will be a day, one day, when no original unit will be in working condition anymore. It is already getting more and more difficult to get hold of good working ones. New ones out of the box are a rarity since a couple of years. Due to the great resilience of the units in the first place, the amount of spares produced was quite small. On the other hand, there are good reasons to think about ways to keep Hydrolastic working. For one it was one of the defining features of the ADO16, so an important part of keeping one of these in original condition to preserve as a classic. On the other hand the ride experienced with Hydrolastic cannot be replicated with a conventional setup. The reason is, that both spring rates and damping rates are highly progressive, both increasing with the load of the car in a way that the car 'feels' roughly the same, independant of the load. And this is before getting the interconnection of the units on each side into play. Today similar effects are achieved using very sophisticated computerised adaptive damping and anti-roll systems.
The late Dr. Alex Moulton was well aware of the problems owners of cars with 'his' suspension system may have in the future, as well as some shortcomings particular in the ADO16. During a couple of meetings over the past 10 years he has shown me a possible solution.
There are generally 3 problems arising with Hydrolastic units:
1) The lower diaphragm, which houses the push-rod with the cone may split. In many cases a damage of this membranes can occur if there is dirt or corrosion trapped between the cone and the rubber. If a unit is out of the car, it is adviseable to clean this area.
2) The rubber hose attached to the units may split. This problem has already been dealt with. A new hose can be attached by using a strong clip, as is done by the Landcarb (1800) club for some time now. This is close to the way the original fitting was attached and the preferred solution for durability.
3) The rubber spring ages and may eventually burst. This is a slow process and usually shows itself in the spring 'bulging' out of the unit together with a slight degradation in ride quality over ridges or small bumps.
There is not yet a possibility to deal with problem 1), as this would not only mean to open the unit, but also to have the diaphragm remade. So trying to keep this in good shape seems necessary. As stated, failure 2 can be rectified by adding a new hose. This leads to dealing with fatigue of the rubber spring itself.
Dr. Alex Moulton has put some thought into this issue and came up with two possible solutions. The first idea was to add a flat steel-spring on the top of the Hydrolastic units, taking on the load as long as the rubber spring itself has no leaks. In some cars this idea would have lead to installation problems due to space requirements. Discussing this with contacts in the car supplying industry the conclusion is that it will actually be possible and not very expensive to remould the rubber springs, even in small series, if the metal parts were supplied. This is the key problem: Due to the needed strength re-manufacture of the steel parts seems to be prohibitive due to the cost involved. So the steel pressings would need to be re-used. The units will need to be opened and re-sealed for this kind of repair.
There are three major steel parts forming a Hydrolastic unit: One almost tube shaped piece containing the rubber spring (or rubber cheese, as Moulton called them), a 'hat' shaped part containing the damper and separating spring and displacer in the middle and last the cut-off cone containing the displacer diaphragm with the actuating rod and cone. During fabrication all three parts with all internals were put into a press and then the overlapping edge was rolled to form the rim in the centre holding all three parts firmly together. The first step, opening them, is relatively straight forward: The rolled part of the edge needs to be carefully removed. The three parts can be separated afterwards from each other for inspection and replacement of rubber parts.
Dr. Moulton came up with a solution how to close the units again. Three rings where manufactured, practically creating a kind of compression fitting held together with a large captive nut in the place where the original joint was. The ring around the spring unit needs to be split in halves to be able to be fitted, whilst the other ring and the captive nut can be slid over the unit from the displacer end. Tightening these should be done in a hydraulic press similar to the original process. Dr. Moulton actually has had a prototype made and put it into a test bed to check the unit after refitting successfully.
So right now the plan is laid how Hydrolastic units can be partially refurbished. The rubber internals and the connection hose can be renewed using the method described above. Also the possibility of combining intact parts of units to a working one is given. As the damper valves are also accessible when the unit is dismantled, these can also be renewed or even modified to address the weakness of the installation in the ADO16.
Right now it would be worth considering that the club, or individual members, collect all Hydrolastic units, even those with defects. Dr. Moulton advised us not to throw any of them away to secure the future use. They might - apart from directly keeping cars on the road with intact units - be a valuable source of spares for the reconditioning process of Hydrolastic units.
Read more: http://landcrabforum...2#ixzz3wr5kxKyF
#5 mab01uk
mab01uk
  • 12,413 posts
Posted 10 January 2016 - 08:02 PM
Also a trial repair to the top rubber area of an Austin 3 Litre displacer unit below.......
(At least Hydrolastic Mini owners have rubber cones available if all else fails but of course most other BMC/BL Hydrolastic cars have no long term alternatives).
Quote:
"Just to recap on what I think is achievable with regard to repairing these units, the three failures are; hoses split, top rubbers burst open, lower rubbers burst open. From a repair point of view, hoses are easy to replace, a burst lower end is beyond hope of repair currently, a burst top end I felt could be repaired and I have managed to do just that. Some of the problem with the top end is the rubber thickness is quite thin, once this thin film perishes and splits open water gets in and attacks the top of the valve area, this of course causes more deterioration. I thought if I could get a liquid rubber that would bond to metal and existing rubber, and cope with some flexing and contain the 250 psi of fluid pressure within the unit it may be possible to repair one. I have two spare units which are both split and leaking from the top so I decided to use these as the basis for my trials......
(see PDF link below for further details and photos)
http://www.austinthr...y June 2014.pdf
Edited by mab01uk, 10 January 2016 - 08:03 PM.
#6 mab01uk
mab01uk
  • 12,413 posts
Posted 14 April 2016 - 10:15 PM
Some photos of a set of NOS displacers..... :mrcool:
https://mmalleck.smu...ni-hydrolastic/
Edited by mab01uk, 14 April 2016 - 10:26 PM.
#7 mab01uk
mab01uk
  • 12,413 posts
Posted 12 September 2016 - 11:11 PM
First 10 pages of this PDF (link below) is an in depth detailed technical article on the ADO16 Hydrolastic suspension (Sep 1962) and the last 9 pages are devoted to the Austin 3-Litre Hysdrolastic suspension (March 1968) both are from the 'Automobile Engineer' magazine.
Hydrolastic Springing - Automobile Engineer - Sep 1962
The Design & Development Story for the Morris 1100 suspension as told by Alex Moulton
http://copeland.id.a...Hydrolastic.pdf
Testing%20Hydrolastic%20Unit-2_zpsxdjibh
Hydrolastic%20Testing%20-3a_zpsgbzq57us.
#8 mab01uk
mab01uk
  • 12,413 posts
Posted 08 June 2019 - 10:39 AM
1964 Huffaker MG Liquid Suspension Special
"The 1964 MG Liquid Suspension Special represents many of the changes that swept through the Indianapolis 500 in the mid-1960s. This car was developed by Kjell Qvale, owner of the British Motor Car Distributors (BMC) in San Francisco, and famous race car engineer Joe Huffaker. It was crafted with a chrome molybdenum space frame and was powered from the rear by a 255 cubic-inch Offenhauser racing engine. It was test driven by the famous A.J. Foyt who set a track record at Phoenix. It was raced by great drivers, namely Walt Hansgen, Bob Vieth, Jerry Grant and Wally Dallenbach. It is named the 'Liquid Suspension Special' because it used the same ADO16 Hydrolastic units as used in the production MG sedans."
https://www.conceptc...on-Special.aspx
#9 DeadSquare
DeadSquare
  • 3,089 posts
Posted 09 June 2019 - 01:42 PM
I once started building a front wheel drive, Imp engine single seater with moded Mini front suspension so that the rubber doughnuts were facing each other horizontally, as pictured above.
Then I got married !
#10 mab01uk
mab01uk
  • 12,413 posts
Posted 08 September 2019 - 08:29 AM
Another section through a Mini Hydrolastic Displacer
Hydrolastic Service:-
https://hydragasandh...lastic-service/
MiniMail - Hydrolastic Displacers
We have developed a way of putting a new hose on hydrolastic units . We offer (when available) refurbed used units that have been pressure tested,checked and repainted with new gaiter and a new hose .  These are done on an exchange basis.
https://www.minimail.co.uk/parts/
Edited by mab01uk, 24 September 2019 - 08:30 AM.
#11 mab01uk
mab01uk
  • 12,413 posts
Posted 09 May 2020 - 09:17 AM
#12 mab01uk
mab01uk
  • 12,413 posts
Posted 04 July 2020 - 06:07 PM
Interesting extract below from an article on Keith Dodd of Minispares attempts at getting the Competition and Standard Hydrolastic units remade back in the early 1980's:-
http://www.minispare...nlop-Suspension
"Between 1978 and 1981 Dunlop USA spent $102 million on modernising its European tyre business. The British workforce was cut from 13,000 to 7,000 with departments being closed down, hence the probable loss of the hydrolastic tooling . It was after a disastrous merger with Pirelli in 1971 until 1981 that indirectly lead to the whole Dunlop group of companies being sold to BTR in 1985. BTR who also made the many rubber body seals for the mini gradually split them up and sold them off, with the Systems and Components division transferring to Trelleborg AB at the end of the 1990's, but a management buyout in 2007 allowed the company to modernise, culminating in the current building which was completed in 2014.
I had always been trying to get Alex Moulton to help in getting the competition hydrolastic units remade early 1980's and standard units again especially after Rover made them obsolete when stocks run out in 1989 but he had no interest at all saying they were too difficult to manufacture and that he would not part with any drawings or any help in the manufacturing process at any cost. Alex Moulton also reflected on the cost and scrap rate encountered, but my contacts in Rover etc were unaware of any major production problems. Unbeknown to me Dunlop had discontinued making displacers in 1978 and must have suffered any losses themselves as I never had any warning the huge testing equipment and tooling would be scrapped and as sales were quite low the "all time buy" by Rover allowed them to carry on selling them at £27 to Mini Spares and other main dealers for over 10 years without any increase. Rover all time buys were usually 10 years worth of stock holding where they are obliged to keep replacement parts and the tooling was often scrapped (a bad policy for classic car owners but saved companies large amounts of money on storage of machinery or tooling and their replenishment costs which made good business sense at the time). In 1994 I bought my last 200 displacers sourced by Tony Fitchet who was Rovers scrap and clearance contractor at £52 each. I paid a lot more for odd new units that I could subsequently find afterwards.
Having spoken to Alex on quite a few occasions about hydrolastic units I also enquired about the Innocenti suspension cones I had discovered wondering if with his contacts he could get them made. (Plus the standard type of course as the only source available were Rovers made by Dunlop which were expensive.)
Big mistake! As he hated anything being uprated or stiffened but I debated the fact that many car manufactures were now fitting anti roll bars and stiffer suspensions for better handling. (BMW). Later interviews and articles regarding Alex Moulton also showed or indicated his complete dislike for the New Mini with its firm suspension."
Innocenti 120 Rubber Cones:-
"During a trip in 1984/5 to Ivra the Mini and Innocenti parts manufacturer and stockist in Milan I noticed some strange shaped rubber suspension cones that transpired to have been used on the heavier Innocenti 120 mini, produced from 1978 that was fitted with the 1275cc British Leyland power plant producing 74BHP. The Mini 90/120 cars production had finished by 1982 and having never seen this shape cone before I was intrigued enough to buy 100 for trial and found positive results and great feedback from rally drivers and performance mini owners, so I purchased the remaining stock of about 800 in January 1986 which lasted until 1993. It transpired Dunlop developed this shape to stop body roll on this taller heavier hatchback model to help change the ride over the cobbled or undulating Italian streets.
I contacted Dunlop about these special rubber cones with patent number 620734 but they were very reluctant to offer any help as they held the patents with BL/Rover, but having had 5000 of the Cooper S Wheels 21A1286 remade in 1980 by Dunlop I managed to find out from my contacts the bad news that the tooling had been scrapped and they had no interest in resurrecting the product (the same old sad story would unfold similar to the hydrolastic units)."
Edited by mab01uk, 08 July 2020 - 07:22 AM.
#13 mab01uk
mab01uk
  • 12,413 posts
Posted 27 April 2022 - 06:47 PM
Autosport page scan: Sporting Minis: https://www.facebook...esportingminis/
#14 mab01uk
mab01uk
  • 12,413 posts
Posted 22 May 2023 - 07:24 PM
