Bp7Es - Bpr7Es
15 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 09 January 2015 - 12:56 PM
the plug leads I have on at the moment have a copper core
running the bp7es any problems with this as far as engine wise,
module, etc
#2 jaydee
jaydee
  • 8,565 posts
Posted 09 January 2015 - 01:18 PM
Use the R type.
The difference is only about 1kohm extra resistance and its enough to suppress unwanted interferencies thay may effect the module.
#3 racingbob
racingbob
  • 3,061 posts
Posted 09 January 2015 - 04:00 PM
Use the R type.
just ordered some ta will try
#4 Spider
  • 14,840 posts
Posted 09 January 2015 - 06:55 PM
Also, by adding some resistance to the HT Circuit, the Spark will Spark for a longer period.
#5 racingbob
racingbob
  • 3,061 posts
Posted 09 January 2015 - 07:11 PM
is that right so its best to use the bp7Res no matter what leads you use
it gets a bit confusing for me in my old age
don't the BP7es have a R on the plug haven't got a plug with me
but looking at photos on ebay theres a R on the plug even tho says BP7es
#6 Spider
  • 14,840 posts
Posted 09 January 2015 - 08:19 PM
Too much Resistance isn't a good thing either, around 12k to 16k ohms as a guide would be fine.
If using Copper, like yours, then yes, the BP7RES would be the go, however with most Silicon Insulated leads (which usually have a Carbon Core), then the straight BP7ES's.
The photos that are often used on ebay are 'indicitive only', however, I'd suggest buying them over the counter.
#7 racingbob
racingbob
  • 3,061 posts
Posted 09 January 2015 - 08:38 PM
ok ta
#8 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 10 January 2015 - 11:02 AM
Iuse BPR6ES on a standard 1275 sprite
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 January 2015 - 04:16 PM
In general, use "R"s, resistive plugs on those equipped with electronic ignition systems and the non resistive on those using points..
Also 6's are pretty much the defacto standard for plugs, only go up to 7's if you start burning out electrodes.... you may end up with a weaker spark using the wrong temperature plug.
#10 racingbob
racingbob
  • 3,061 posts
Posted 10 January 2015 - 05:00 PM
reason got 7's is got high compression must be 11.1
see if I can get touch out the chambers when head comes off
#11 racingbob
racingbob
  • 3,061 posts
Posted 11 January 2015 - 05:20 PM
let me get this right
if I am running copper leads I need to use bp7res plugs
if other leads can use bp7es
this is on my 65d dizzy
as copper leads and bp7es plugs may damage module ??
#12 Spider
  • 14,840 posts
Posted 11 January 2015 - 07:54 PM
Bob,  I've filled in some answers in Red
if I am running copper leads I need to use bp7res plugs               Yes
if other leads can use bp7es        Yes
this is on my 65d dizzy        Don't see an issue
as copper leads and bp7es plugs may damage module ??         No, they won't damage the Module. About the only things that will damage the Module is a Shorted Coil (on the LT Side),
        High Temps and excessive Voltage (from memory, they were tested to 17.5 Volts)
#13 racingbob
racingbob
  • 3,061 posts
Posted 11 January 2015 - 08:07 PM
what if I used those historic type plug caps from ngk that srcew into the lead they say supressed
http://www.moss-euro...teIndexID=12564
moss bros sell them about £3 each, can I use the bp7es then
#14 Spider
  • 14,840 posts
Posted 11 January 2015 - 08:56 PM
Yes, no issues there.
#15 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 21 January 2015 - 11:49 AM
Rather than start yet another thread on plugs I thought refer to this one and have a look on my favourite plug site.  They threw up 8 different BPR6ES!
 http://gsparkplug.com/catalogsearch/result/?q=BPR6ES
Which one for a no-name electronic ignition on a fairly standard 1293?
